Sponsored by: CARiD
wastegate question
Old May 8, 2009 | 07:38 PM
tatu2183's Avatar
wastegate question
i put on a external wastegate on my rx7 with a screamer pipe..i thought i had an exhaust leak when the car is just idling,but i noticed it was comin from the wastgate. is the wastegate supposed to be closed until needed to open?
Old May 12, 2009 | 06:51 PM
tatu2183's Avatar
should i reword the question????
Old May 13, 2009 | 02:08 AM
Black Hearts's Avatar
Capoeira Centre Sul
by screamer pipe do u mean the dump tube?
my old setup had a tial wastegate and it only sounded loud under load.... not too positive on how it should work but i can ask my mechanic and get back to you in the afternoon.
Old May 13, 2009 | 02:17 AM
Capoeira Centre Sul
nvm...google was my friend
"The wastegate (WG) is part of a feedback loop used to limit boost. The boost controller, be it manual or electronic, the turbo, and the wastgate make up the elements of the loop. As boost builds, the controller monitors the pressure. When the pressure exceeds the controller's set point, it supplies air pressure to the WG actuator (the thing that moves the WG). The WG opens and diverts some of the exhaust flow away from the turbo. The turbo slows a little and the boost drops to below the controller's set point. When this happens, the controller stops supplying air to the actuator and the WG closes. The cycle repeats over and over until you stop nailing the accelerator!
How much the boost varies about the set point is a function of the "gain" of the loop and how much it is "dampened." It's more than you probably want to know.
There is a spring in the WG actuator that has a lot to do with how well the WG remains closed while boost builds. The WG actuator has to overcome the spring force to open the WG. The exhaust gas pressure isn't very significant so the actuator has to do most of the work. The spring force has an affect on the "gain" of the loop, so it can affect the loop response time.
so to answer your question; yes its suppose to stay closed unitl needed
Old May 13, 2009 | 12:33 PM
Rotary?Cool's Avatar
top row 2nd from left..me
Mine leaks at idle as well. Its normal for some WG's not running a boost controller or ones that don't have the adjustment nut on top.
Old May 16, 2009 | 04:56 PM
tatu2183's Avatar
ok...thanx..i have a hks evc..and the wastagate is cheap jdm sports...but im to a hks...i wanted to kno b4 i take to the tuning shop...wanna have the car running rite..u kno
_Tones_
May 25, 2021 05:37 AM
Ian_D
Oct 14, 2015 12:31 PM
Nosferatu
Sep 5, 2015 02:13 PM
