Rtek Forum Discuss the Rtek 2.0 and other Rtek ECU's
Rtek Rtek 1.x vs. 2.x Timing Maps
Old May 8, 2009 | 02:33 PM
RotaryRocket88's Avatar
Top Down, Boost Up
I'm currently running an Rtek 1.7 chipped N332 ECU, but will be upgrading to the 2.1 in the near future. What I'm wondering is if the "timing retard over 9psi of boost" feature of the 1.5, 1.7 & 1.8 is incorportated into the base timing maps for the 2.1.
Also, does this mean that the 1.x chips use MAP based timing rather than LOAD based? Or are the timing adjustments made at the approximate LOAD conditions where the stock turbo would be pushing over 9 psi of boost?
Old May 10, 2009 | 09:13 AM
arghx's Avatar
rotorhead
I've wondered about this myself.
Old May 10, 2009 | 10:48 AM
turbo2ltr's Avatar
After the ECU calculates what it think the timing should be (its not as simple as looking it up on the map, though that is part of it), we come in and retard it based on the MAP sensor reading.. It's two separate calculations. The stock method is load based, and its the same no matter what you are running, with the exception of the 2.1 in MAP based timing mode.
You cannot effectively recreate the retard function in the 2.1 without running MAP based timing mode.
Old May 10, 2009 | 04:13 PM
Top Down, Boost Up
Ah, ok. That makes much more sense. And, yes, I sent you guys an email asking the same question. Thanks.
Old May 12, 2009 | 04:52 PM
J.MurdaFCs3's Avatar
Hookt UP
turboltr.. whats the turn around time on a 2.1 install right about now??
Old May 12, 2009 | 04:54 PM
turbo2ltr's Avatar
Typically it's one business day from time of receipt. Though we have a lot of orders right now where people didnt send in their ECUs yet. So in the case we get like 5 on the same day, the turnaround time may be pushed to 2 days.
Old May 13, 2009 | 10:35 PM
Top Down, Boost Up
Mine's one of those on your list. It's scheduled for delivery on Tues. the 19th. Too bad it has to go all the way to PA and back .
smikels
Rtek Forum
May 12, 2016 12:34 AM
Microtech
30
Apr 23, 2016 06:37 PM
Microtech
Aug 23, 2015 11:04 AM
befarrer
Microtech
Aug 22, 2015 05:52 PM
baconflavored
SE RX-7 Forum
Aug 12, 2015 12:07 AM
