Magneto?
Old May 7, 2009 | 06:13 PM
mattmiller6977's Avatar
Exclamation Magneto?
So, I was looking at a blue second gen rx7. The owner said it needs a new magneto and it should run. Where would I even buy one of those?
I didn't even know rx7's had magneto's to begin with.
Old May 7, 2009 | 08:14 PM
IanS's Avatar
Ricer
No magneto in a 2nd gen. Where the distributor "would go" is what is called a crank angle sensor. I have an extra one you can have. Most likely isnt the problem. Where are you located?
Old May 8, 2009 | 02:00 PM
Aaron Cake's Avatar
Engine, Not Motor
Hm, if all it needs is a CAS to fix, then why doesn't he fix it?
Harshjay
May 5, 2015 10:11 PM
sherff
Nov 29, 2014 12:26 PM
Aviator 902S
Old School and Other Rotary
May 27, 2003 07:24 PM
