Sponsored by: CARiD
Oil in only one manifold runner?
Old May 2, 2009 | 10:06 PM
black93RX7's Avatar
20BFD
Why would cause oil to be in only one of my intake manifold runners?
The car had been running only on one or two rotors due to foulded plugs, would this be a contributing factor?
Thanks,
Erik
Old May 2, 2009 | 11:25 PM
Hi Erik,
years ago I noticed the same phenomenon on my FD, which was running perfectly fine at the time.
In the recent past I had an ignition amp fail on me, leading to only my trailings firing for some miles (happened in the middle of a trip). I've surmised that was the case, not really sure.
Old May 3, 2009 | 12:53 PM
black93RX7's Avatar
20BFD
Thanks, certainly sounds plausable.
Which igntion amp are you using? I am having bad break up starting at 5000rpm and am considering an amp to try and fix the issue.
Old May 3, 2009 | 01:23 PM
The HKS Twinpower. It isn't cheap, but it freaking works, and works well. I ran jacobs amps for years but after three failures I gave up on them. havent looked back since
Old May 4, 2009 | 10:25 AM
black93RX7's Avatar
20BFD
I had a twin power and it worked on my 2 rotor, but sold it when I went 20B. Trying to decide what system to go with for the 3 rotor.
C. Ludwig
Jan 30, 2019 06:31 AM
Turblown
Vendor Classifieds
Aug 18, 2015 10:01 PM
