Base Fuel Pressure?
Old May 29, 2002 | 07:54 AM
forcefed1's Avatar
Base Fuel Pressure?
I hooked up a digital fuel pressure gauge to monitor my stock system.
at 0 PSI boost I see 40 PSI fp.
at 10PSI boost I only see 44 PSI fp.
at 14 vac I see 35 PSI fp.
while this seems to be a linear change it is not 1:1 like I thought it should be.
does anyone have a stock fuel system and care to share your info?
Is this normal for stock?
Is my FPR not working correctly. sounds like I have a leak on the vac line compared to what I thought I should get.
Old May 29, 2002 | 08:56 AM
cewrx7r1's Avatar
Eye In The Sky
Per the manual and other sources; with stock FPR and stock FP or similar FP and by my memory:
idle: 28-32 psi
0 boost: about 38psi
boost: the 0 boost pressure(38) + boost pressure
If at 0 boost you have 38psi fuel pressure, then at 10psi boost the fuel pressure is 38 + 10 = 48psi.
Try using a mechanical FP gauge with a long hose run into the car for a quick side by side test. Either your new gauge is off or you FPR and/or pump or bad.
I had an Intellitronix digital FP gauge and it was trash. My AutoMeter one is accurate.
Microtech
30
Apr 23, 2016 06:37 PM
Snoopy FD
Dec 8, 2015 01:45 PM
