metering pump
Old May 29, 2002 | 03:03 AM
Talking metering pump
I was wandering if the oil pressure gauge told you if the metering pump is working.
Old May 29, 2002 | 03:17 AM
4ohfour's Avatar
I don't think so, the Oil metering pump is supposed to pump something like 0.7ml of oil into the carb (at the base) evey min.
The best way to check to see if it is in fact working is to disconect the lines and put them into a container and run the engine for a few mins... Measure the amount of oil, then note the time the engine was running and figure out how much it is putting out per min.
cheers'
Old May 29, 2002 | 03:53 AM
thanks
Old May 29, 2002 | 06:00 PM
85RX7GS's Avatar
Yey
Old May 29, 2002 | 06:29 PM
82streetracer's Avatar
8/1 Building/Drive Ratio
I know there are kits to run 2 stroke through the omp
does anyone have the link for this.
BLK 93
11
Sep 9, 2015 10:56 AM
