spare tire for RZ brakes
Old May 1, 2009 | 12:12 AM
rx7will's Avatar
What spare tire do you guys with the RZ brakes or big brake kits use. It would suck to be stranded because i did not have a spare tire.
Old May 1, 2009 | 09:12 AM
Sled Driver's Avatar
The Anti-Prius
I purchased Mustang Cobra GT aluminum 17" spare tire off ebay . I understand the Supra 17" spare will also fit. (bolt pattern, offset)
The only problem was it comes with a T145/70D17 tire mounted on it.
It only fits in the spare tire cavity if its completly deflated. Defeating using it as a spare.
Got the proper OE size tire from Tire Rack (T125/70D17) & all is good now.
Old May 1, 2009 | 09:36 AM
gracer7-rx7's Avatar
needs more track time
Brilliant.
What year Mustang is that?
Old May 1, 2009 | 09:56 AM
vel525's Avatar
Woo Hoo, It Runs!!
Hmm, i need to do this as well. Any pics?
Old May 1, 2009 | 05:38 PM
billyboy's Avatar
Probably be over the tipping point from a cost perspective once shipping is factored in, the proper alloy one with tyre was on the Japanese auctions a couple of weeks back. If you are really flush, you could order a new rim, 99650-14070.
Old May 1, 2009 | 08:01 PM
KKMpunkrock2011's Avatar
dorito powered
Originally Posted by gracer7-rx7
Brilliant.
any 5-lug bolt pattern mustang, they're all the same, I needed a spare and I borrowed one of the bullitts my buddy had lying in his garage, that looked a little awkward
Old Jun 23, 2009 | 07:01 PM
I found one locally from a 2005 Mustang. It fits!
https://www.rx7club.com/showthread.p...18#post9310418
I wonder if the spare from the RX8 or Mazdaspeed3 work? They are 17" spare rims with the correct sized tire mentioned above.
josef 91 vert
23
Sep 3, 2015 11:20 AM
