Tein springs really compressed! [FD]
Old Apr 30, 2009 | 12:34 PM
Oliv's Avatar
Need a tune
Hi guys,
Just had my new tein springs and kyb gr2 struts installed. Also replaced everything that comes with fr & rr (boots, stops, etc...)
I noticed that the front springs are so compressed that the coils touch each other at the top.
Is that normal??
Old Apr 30, 2009 | 01:13 PM
gracer7-rx7's Avatar
needs more track time
Sounds odd. Do you have a pic?
Old Apr 30, 2009 | 01:40 PM
Oliv's Avatar
Need a tune
Sure:
1st one is front left
2nd one is front right
3rd one front left again: seriously needs alignment
Attached Thumbnails Tein springs really compressed! [FD]-front-left.jpg   Tein springs really compressed! [FD]-front-right.jpg   Tein springs really compressed! [FD]-front-left-alignment.jpg
Old Apr 30, 2009 | 02:10 PM
That certainly does not look normal. Did you buy the springs new?
Old Apr 30, 2009 | 03:25 PM
Oliv's Avatar
Need a tune
****! Yes brand new! PN SKM50-AUB00
I don' remember hosw they looked like before install (they've been in their box in the garage for a while before I bring the car to the mechanic).
But I found pics on the web, not FD ones but you can notice that they almost touch.
Someone has a pic of theirs un-installed yet?
Old Apr 30, 2009 | 04:14 PM
habu2's Avatar
Three questions:
1. what spring rate are the springs?
2. what is the free (uninstalled) length of the springs??
3. what is the installed length of the springs?
Old Apr 30, 2009 | 05:35 PM
Oliv's Avatar
Need a tune
Spring rate
Front
kgf/mm: 7.8
lbs/in: 436
Rear
kgf/mm:5.8
lbs/in: 321
Ride Height Lowering
Front
mm: 36
in: 1.4
Rear
mm: 33
in: 1.3
Old Apr 30, 2009 | 06:48 PM
Josh18_2k's Avatar
those are S-Tech's, which are progressive. the tops are softer, allowing the car to soak up bumps smoothly, then they get stiffer as they compress in corners.
its normal
Old Apr 30, 2009 | 10:51 PM
MrMigs's Avatar
Or they may be what are known as "dead coils" which basically just keep the spring in place within the shock perches. That way, when your suspension is in full droop, the springs won't dangle. I know some springs are made thsi way .... not 100% sure about those ones though.
Old May 1, 2009 | 07:27 PM
Josh18_2k's Avatar
that makes more sense.
as you can see in the stock photo, the top of the spring is almost all the way compressed.
if it concerns you that much, take them out and flip them, so you can see that the other end of the spring isnt fully compressed.
Old May 1, 2009 | 08:58 PM
Mahjik's Avatar
Mr. Links
Here's a shot of one of my fronts with the car on jack stands (i.e. full droop):
Old May 2, 2009 | 05:20 AM
Oliv's Avatar
Need a tune
Thanks for the inputs guys, I feel much better now.
Mahjik, thanks for the pic! Could you just confirm that when the car is down on her wheels the top of the springs is so compressed that the 4 top coils are touching each others. I'm now 99% sure it's normal as I see that there are some brown plastic protections...
Old May 2, 2009 | 09:38 AM
Mahjik's Avatar
Mr. Links
It will be a while until my car hits the ground. Half of the rear suspension is off waiting for some replacement parts to get shipped. Given how my springs look at full droop, I would imagine those top 4 coils are probably compressed once on the ground. However, it's a little difficult to see once my car is on the ground:
Old May 2, 2009 | 01:07 PM
Oliv's Avatar
Need a tune
Looks good! I think you're right Mahj.
I had the bushngs changed for the Delrins during the install. I've not yet gone to get everything aligned.
Now when I turn the wheel completely right the left tire touches the arch. Bad re-install of the arms or just alignment that needs to be done?
Haven't checked yet if I have the same issue with the right tire.
Old May 2, 2009 | 09:17 PM
Mahjik's Avatar
Mr. Links
When you say arch, do you mean the car fender? You'll mostly likely need to roll your fenders if you haven't yet for these springs.
Old May 3, 2009 | 04:38 AM
Oliv's Avatar
Need a tune
No I'm saying the inner black plastic arch inside the fender.
I'm still on stock wheels.
The fact is that my left front wheel is too much in the front.
Old May 3, 2009 | 07:12 AM
rizzxx7's Avatar
DIGG7ER
how does it ride? is it ungodly stiff or is it a pretty smooth ride?
Old May 3, 2009 | 08:17 AM
Oliv's Avatar
Need a tune
Definitely stiffer than stock, not smooth at all.
Don't forget I also have Delrin bushings, lot stiffer than stock.
But I drove it only a few miles from the mechanic to my place. I need more experience and to get everything align to post more reliable feeling.
Old May 3, 2009 | 09:44 AM
Mahjik's Avatar
Mr. Links
Part of the problem could be your shocks. The KYB's are going to basically be an OEM damper, which IMO the Tein's are too high of a spring rate (and too much of a drop) for the OEM damper.
Old May 3, 2009 | 12:54 PM
Oliv's Avatar
Need a tune
Hmmm I see.
But the commercial of the tein s-tech is that hey've been developped to be used with OEM/OEM replacement shocks...
I would have been fooled?
Old May 3, 2009 | 01:01 PM
Mahjik's Avatar
Mr. Links
The Tein S-Tech are almost double the spring rate of the OEM springs. If you look for some of my older posts, I don't recommend the S-Tech with the stock shocks because of their spring rate (as well as the amount of lowering they do).
Old May 3, 2009 | 01:29 PM
Oliv's Avatar
Need a tune
Well, not really good point for Tein then to make this kind of advertisement.
Should have been more carefull before installing these I guess.
I plan to install in the mid term some aftermarket wheels on top of that...
Old May 8, 2009 | 11:11 AM
Oliv's Avatar
Need a tune
So little review after a few miles of using this set-up: well if you're after some comfort, don't go for the s-tech!
As Mahj said these are really stiff and basically you're body's boucing on your seat a lot.
You'd better not having any digestion problem or you can say good buy to your breakfast...
Apart from this: just great handling!!
Old May 8, 2009 | 06:22 PM
Josh18_2k's Avatar
your dampers are too soft for the springs, hence the bouncing.
if theyre adjustable, crank them to full stiff.
Old May 8, 2009 | 06:49 PM
rizzxx7's Avatar
DIGG7ER
correct, I had thought it was the other way around years ago. I had my shocks to the lowest setting and my car was bouncing all over the place until I cranked it almost all the way up.
