Shifter trouble
Old Apr 29, 2009 | 08:26 PM
N3CR0SAG3's Avatar
N3CR0SAG3
Exclamation Shifter trouble
hi i just bought a 1989 rx7 gxl, there are a few problems with it but the one that has stumped me thus far is that whenever i shift into 1st or 2nd it seems as though the shifter dislodges, it shifts into gear and everything fine and stays in gear but the shifter dislodges so i basically have to push the shifter diagonally left or 1st and diagonally bottom left for 2nd, can anyone help me????
Old Apr 29, 2009 | 08:47 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Sounds like a bad or missing shifter bushing. The shifter comes out fairly easily, so you can check what's going on. New ones can be bought at www.mazdatrix.com.
Old Apr 29, 2009 | 10:49 PM
tunerboy09's Avatar
blown motor!!!!!!
i have had the same problem with my 87 gxl but it only happens on mine when its cold for some reason but on yours it does sounds like the bushing
Old Apr 30, 2009 | 11:19 AM
Top Down, Boost Up
Your issue is probably gear oil related. A lot of gear lubes (synthetic or convetional) don't lubricate as well when they're cold. But as the oil temp increases, the viscosity decreases and allows for smoother shifting. So, maybe you have a combination of bushing issues and cold trans oil making shifting that much harder.
Old Apr 30, 2009 | 12:21 PM
N3CR0SAG3's Avatar
N3CR0SAG3
thx u guys ill let u know how it goes
FC3S Timmy
16
Oct 3, 2015 01:08 AM
Rotafuzz
Sep 30, 2015 09:55 AM
Red-Dragon_Akuma
Sep 28, 2015 06:09 AM
