Arghh, Need to Get Rid of the 3k rpm Start Up Bull $hit
Old May 28, 2002 | 06:57 PM
mightyslash's Avatar
Will Work for Ferrari
Angry Arghh, Need to Get Rid of the 3k rpm Start Up Bull $hit
It used to work when I started in gear (rpm was 1.3-1.5k on start up instead of 3k) , but now it jumps to 3k rpm no matter what gear I'm in. Anyone know how to get rid of it completely? Thanks for any help.
Old May 28, 2002 | 07:07 PM
Johnny's Avatar
OG
Power FC...
blip the throttle on start up
Old May 28, 2002 | 07:08 PM
rxshun7's Avatar
Before my pfc I used to just give the throttle a slight tap after start up. The revs would settle then.
Old May 28, 2002 | 07:09 PM
Wargasm's Avatar
Weird Cat Man
it's not hard. get your manual and remove the "AWS" ('accelerated warmup system' I think). Basically you look on the back of the intake elbow and you see a fat hose coming off of there and going around the back of the throttle body to a port. There is a solenoid there also. Rip off the hose and plug up the end upstream of the throttles and then unhook the other end and the solenoid and make a block off plate for it.
Brian
Old May 28, 2002 | 07:10 PM
rxshun7's Avatar
beat me to it johnny. you must have submitted your reply a few seconds before me. doh.
Old May 28, 2002 | 07:20 PM
Thanks guys. I know I should blip the throttle, but the thing is I dont want the rpm to jump to 3k on start up. Blipping the throttle would not prevent it from jumping to 3k, it would only help to settle the rpm after you start it. I guess I'd just do what Wargasm suggested.
Old May 28, 2002 | 10:12 PM
Jonesboro's Avatar
AWS Modification
This link discusses the AWS modification in detail:
http://www.scuderiaciriani.com/rx7/AWS_mod.html
Old May 28, 2002 | 10:27 PM
93TTRX7's Avatar
why would it still do that if you started in gear?
Old May 28, 2002 | 10:30 PM
I want to know too. This trick only works once in a while, most of the time it just jumps to 3k rpm no matter what.
Old May 28, 2002 | 10:33 PM
7-sins's Avatar
thats not paint....
Next time your under your UIM pull that crap off. If you have the PFC, I noticed my start up idle was very high until I closed off my air bleed screw all the way.
Kyo
Apr 13, 2019 09:24 AM
Microtech
30
Apr 23, 2016 06:37 PM
The Shaolin
Sep 14, 2015 07:50 PM
CaptainKRM
14
Aug 26, 2015 09:52 PM
torky007
Aug 17, 2015 05:14 PM
