SCOTLAND? Help!!!
Old Apr 25, 2009 | 11:19 AM
BrodieRX7's Avatar
rex powa!
SCOTLAND? Help!!!
Enyone know if there is enywhere in scotland that works on rx7s. Im having problems because my rex aint been running right for 9 months and i cant get it fixed because i dont know whats wrong with it, and dont know enyone that can look at it!, can enyone help me?
Old Apr 26, 2009 | 07:51 PM
dgeesaman's Avatar
Dunno who else is in Scotland, but hopefully you can find a mazda dealer that can do a compression test. That's always good to know for an engine that isn't running well.
What are the symptoms?
Old Apr 30, 2009 | 01:23 PM
BrodieRX7's Avatar
rex powa!
Unhappy rx7 problem
I have done a compression test and jimmys rx7 say it seems fine. the cars at 85 thousand miles and the owner told me it has had a rebuild. What its doing is its cutting out on some gears, in second it revs all the way and in 3rd and 4th it cuts out at 5000rpm for a split second then goes again but wont go past 5000. In 5th it went past 5000rpm and i got to about 5500 and was doing 140mph so i thought i better slow downso i dont know when it tops out in 5th
Old Apr 30, 2009 | 06:06 PM
dgeesaman's Avatar
So your problem then is the engine cutting out.
What is your boost reading when it cuts out? Do you have a boost gauge installed?
Old Apr 30, 2009 | 06:49 PM
Inhaled Caffeine's Avatar
Just a guess but check under it and have the transmission checked to see if the gears are stripped at all. (this could happen if your going slow in one and shift then punch it in the next) iv seen some that are messed up in gears before. its not good looking. that may be it.....
Old May 2, 2009 | 01:23 PM
BrodieRX7's Avatar
rex powa!
Rx7 problems
Im going to buy a boost gauge to see what its boosting at. I dont think its the gear box because the car was fine when i first had it. Seems like its fuel or electric? need to get a boost gauge first!
geordieg
Dec 26, 2014 03:36 AM
Sooperkent
Jul 29, 2014 04:40 AM
neilperrett
Dec 14, 2009 05:00 PM
