Buzzing noise from the CP
Old Apr 25, 2009 | 02:39 AM
nh256's Avatar
Question Buzzing noise from the CP
I have a 84 7 and I can't figure out where this buzzing noise if coming from, it's located somewhere inside the steering column I think. It will click on and off similar to the blinker just faster and not as audible. It only clicks when the car is on, not when the key is turned to aux. I was at a stop one day and the clicking sort of shorted out, I seeked professional help and they suggested that it was some sort of relay that may be going hay-wire. Anyone help?
Old Apr 25, 2009 | 08:28 PM
turbofiend's Avatar
i had something similar in my 89 crx and it was the main relay, the main relay is underneath the steering colum aswell, that was makin the noise. and on another car i had there was a buzzing noise and that was cause by a bad ground. dont know if that helps but after knowing that, i was able to fix the problems
Linda_Lovelace
Sep 18, 2015 10:04 PM
RyanFox
Sep 18, 2015 09:09 PM
The1Sun
Sep 18, 2015 07:13 PM
The1Sun
Sep 15, 2015 04:45 PM
