West RX-7 Forum Serving California, Nevada, Arizona, Hawaii
Looking to have some custom work done
Old Apr 23, 2009 | 10:26 PM
AF SEE's Avatar
CA Looking to have some custom work done
I'm trying to have some small custom fabrication work done on my FC. Things like making new air intake piping that leads to a cool air box, and having some thin sheet panels made to route air more efficiently through the FMIC and radiator.
Looking for a shop that will do decent work in a timely manner that would not charge me an arm and a leg.
Does anyone here have any good recommendations as to which shop i can bring my car to the San Diego area?
Old Apr 23, 2009 | 10:44 PM
RX710thAE's Avatar
Balls deep...
mmm..dunno about the TID piping, but checkout mariahmotorsports.com for the sheet metal airbox...and check corksport.com for the radiator panel. good luck with your search!
Old Apr 23, 2009 | 10:46 PM
recardo's Avatar
fd
the only shop i know that does custom jobs here in LA is http://www.renesracing.com/ idk about sd
Old Apr 23, 2009 | 10:54 PM
AF SEE's Avatar
CA
Not much of the car is stock. The radiator is quite a bit larger than stock and sits at a slightly different angle. I doubt a standard radiator panel will work.
I'm hoping to enclose as much area in the front of the car as possible so air will be forced through either the FMIC / oil cooler and subsequently through the radiator, or through a separate duct to the brakes.
Thank you for the recommendations. I will look them up.
As for LA, its a little too far for me to have work done there. Thanks anyways
streetlegal?
Mar 17, 2022 02:46 PM
Jun 26, 2016 10:21 AM
82streetracer
Aug 23, 2015 09:28 AM
