12A to 13B?
Old Apr 23, 2009 | 03:41 PM
GreenMachine's Avatar
12A to 13B?
I have an 82 RX-7 with a 12A and I just got a great deal on a weber carbed 13B out of a 1985 GSL-SE and I was wondering what all needs to be changed to be able to accomadate this new engine?
Thanks
Old Apr 24, 2009 | 01:03 PM
Aaron Cake's Avatar
Engine, Not Motor
You will need the front crossmember from the 13B.
It will bolt directly to the transmission. I'm fairly sure that the clutch stuff is the same. If not, swap the flywheel and clutch from the 12A onto it.
You'll need a new exhaust header.
Old Apr 24, 2009 | 04:54 PM
I forgot to say that i got a new header with the deal so i should be good other than the crossmember.
Thanks
vy_MR2
Sep 16, 2015 06:39 AM
heywier427
Naturally Aspirated Performance Forum
Sep 11, 2015 04:49 PM
chiefmg
Sep 10, 2015 07:46 AM
