Megasquirt Quick BACV question
Old Apr 23, 2009 | 11:10 AM
darkfrost's Avatar
Quick BACV question
So, I want to re-install the BAC valve and am figuring out how to wire the circuit.
The FAQ says:
I don't think anyone has done any testing on a v3 board to make it control a BAC valve, but I believe you'd want to change out Q4 with the ztx688 or ztx689, and change out R19 with a 1/2 watt 510 ohm resistor. You can also replace Q4 with a TIP12x transistor, which some have found is more robust than the ztx parts.
So, I picked up the resistor and a TIP122 transistor. Is it just a direct replacement? Of course with wiring the TIP in correctly since it is bigger than what its replacing.
The reason I ask is because this page shows the TIP transistor being wired in differently and with a diode:http://www.msextra.com/manuals/MS_Ex...nual.htm#Fidle
And, I've also seen mentioned a diode in a couple of earlier threads that I searched up here.
Do I have to jump R39, remove Q29 and D8 as well?
This is for a MS1 V3 Board.
Thanks in advance!
Old Apr 23, 2009 | 11:52 AM
muythaibxr's Avatar
MegaSquirt Mod
TO220 devices have a different order for their pins than the TO92 devices (the 2n2222a), so it's not exactly a direct replacement. The diagram should be correct.
Ken
Old Apr 23, 2009 | 01:11 PM
darkfrost's Avatar
So I do need to pick up a diode then?
Old Apr 23, 2009 | 06:33 PM
darkfrost's Avatar
One more thing... The R19 resistor, theres nothing about swapping that in the megamanual.
Are these two methods just different ways of doing the same thing? And I should just stick to one? Preferably the one in the FAQ since it only involves 2 parts?
Old Apr 23, 2009 | 06:45 PM
muythaibxr's Avatar
MegaSquirt Mod
The resistor should be 1k. If that's true then you can just use that.
You do need the diode. That's for flyback protection, and should help.
Ken
Old Apr 24, 2009 | 08:46 PM
Jobro's Avatar
SAE Junkie
I have done it, and it did work. I used a TIP122 or 120 I think, whatever ken said to use. I removed all the parts he said and bolted it to the heatsink where the VB921 normally goes.
Old Apr 26, 2009 | 10:31 AM
Aaron Cake's Avatar
Engine, Not Motor
I've also set up a few BACs using the modkit from DIYAutoTune. There's no resistor included, and the transistor is a TIP120 I think. Connects directly in place of the stock transistor. Seems to work fine with the stock BAC.
Old Apr 26, 2009 | 10:35 PM
darkfrost's Avatar
I picked up the diode and set it up the way it shows on the link I posted. It seems to work fine on crank, but I think I need to play with the settings still for idle. Its always on 0 dc on closed loop mode. Ran out of time to play with it today, I think its my TPS value keeping it off...
_Tones_
May 25, 2021 05:37 AM
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
SakeBomb Garage
Oct 9, 2015 10:05 PM
