new guy needs help...badly
Old Apr 21, 2009 | 07:44 PM
lonely_driver's Avatar
broguht my 1988 SE 7 like 2 months ago, was running fine. its stock. i'm losing oil pressure everytime the it warms up to normal temp n the rpm goes crazy bouncing from 1000-1500. after it warms up since i dont move till the temp gauge moves alil while the rpms bounces then claims down. i come to a stop in neutral it dies. turn it back on. when i moving my oil pressure is fine but when i come to a stop it goes down to 0! to get oil pressure back i hold the gas to 2000rpm. i have fun in traffic...... i changed out the oil n filter n plugs n wires(needed it) please help!!
Old Apr 22, 2009 | 08:50 PM
turbofox37's Avatar
Maybe a bad oil pump? I would say maybe a blown head gasket but I just found out rotaries don't have those...
Old Apr 23, 2009 | 01:12 PM
thejallenator's Avatar
possible oil leak? look for those. i had one and as soon as i fixed it i had way better oil pressure
Old Apr 23, 2009 | 05:14 PM
yesturday i checkd for oil leaks before starting none then i go to start it it floods.... take the relay out n gas n clutch to the floor about 3 times with with 3 secs on n 5 sec pause. put the relay back starts n BOOM! shotgun warmer it up in the drive way for 10minutes checkd for leaks over the hood n under the car none! i'm like ok.... oil pressure was FINE!! wheres the zero?! then when i gave it gas at 3000rpm. it down to 2000rpm n back up n down then off the gas i lose the pressure..... the rotary Gods hate me
Old Apr 23, 2009 | 05:31 PM
RX Pharmacy's Avatar
I would check to see if you have enough oil first. Next check for any leaks. Then see if the oil pump is still good. It can also be a bad sending unit or gauge.
Tylerx7fb
39
May 27, 2019 12:45 PM
Kruel13
24
Sep 16, 2015 09:08 AM
Clacor
Aug 14, 2015 09:17 AM
