1stgen Exhaust Manifolds?
Old Apr 20, 2009 | 06:56 PM
1BadRx7331's Avatar
I have a 85 GSL with a 12a and the stud on the cat side of the manifold snapped when i tried to losen the rusty nut. ide rather not have to drill it out so i went to the local junkyard for a replacement part. he had 1 and it was on an 83 12a. his computer said it wasnt compatable but he has been wrong before. Any help here?
Old Apr 22, 2009 | 06:26 PM
1BadRx7331's Avatar
bump for some help
Old Apr 22, 2009 | 06:31 PM
JoeyMazda's Avatar
"81 RX-7
Does the stud still have a little left that you can grab it with a pair of pliers? If you can still grab it you can get it out like that.
Old Apr 22, 2009 | 06:40 PM
1BadRx7331's Avatar
it does however i was using an air gun so i dont know how torqued down it is haha. plus like i said its terribly rusted and was seized up. on the positive side i have already ordered new studs so they will go back in if i get the old ones out haha
Old Apr 22, 2009 | 06:48 PM
JoeyMazda's Avatar
"81 RX-7
Drill a hole in the stud and try the reversable bits.Try heating it up so the lock tight loosens up.I did it before & it worked.
Old Apr 22, 2009 | 06:57 PM
1BadRx7331's Avatar
i can try that but i still need to know if the 83 manifold will swap 1 for 1
Old Apr 23, 2009 | 01:14 PM
thejallenator's Avatar
get some good **** that will loosen that bolt. stuff stronger than wd-40. cant remember the name of it right now. and then soak it down then try to get it off with pliers
Old Apr 23, 2009 | 01:36 PM
Turn1First's Avatar
Best idea? Get rid of the manifold! Buy a racing beat header and presilencer, you will love the performance increase.
