Sponsored by: CARiD
should i and how to test engine compression?
Old Apr 19, 2009 | 09:18 PM
Perry9394's Avatar
hi, i just found my factory twins turbo was broken, and the primary turbo shows quite some damage to the fin due to the broken bearing and the shaft play is really bad on it, i just wonder if the chips of the fin would go into the engine and cause damage to the seals, i removed all the piping and intercooler but couldn't find any chips, so i guess the best way to test the engine is to test the compression, right? if so is it just the same way to test like other piston engine? do i have to test at both leading and trailing plugs?
Old Apr 21, 2009 | 03:07 AM
WaachBack's Avatar
Finally Knows
You can use a piston motor compression tester.
No, you do not have to test both leading and trailing, either or works.
Old Apr 28, 2009 | 08:14 AM
BadAssRX-7's Avatar
The AUTO DOCTOR
but you hav to mod the piston tester to work on a rotary. and with a mazda tester u do it on the trailing plugs. fyi i have a tester im about to list for sale.... its a 2nd unit and works great but i dont need 2.
efini7
Test Area 51
Sep 4, 2015 02:59 AM
elfking
Aug 19, 2015 09:48 PM
