non seq turbos problem
Old May 28, 2002 | 02:32 AM
Eep's Avatar
Eep
brap
Unhappy non seq turbos problem
I did the non seq turbo mod, it works great, but when Im in 5th gear and I floor it, at 3k rpm the turbos don't kick in and it feels like its hitting the fuel cutoff and it wont go past 3k, but if I gas it really slow it will go past just as long as I don't floor it, any ideas how to fix this?
thank you
nick
Old May 28, 2002 | 05:14 AM
Fd3BOOST's Avatar
Recovering Milkaholic
Ask Dont be a rikki. He may have a suggestion for you.
Old May 28, 2002 | 05:33 PM
importboi22's Avatar
Hks Ownz Me (
we were running stock maps... we dont have anymods except a rear section.. boost was going up to 11psi then 8 after 5k i think not too sure and in fifth it was down to 9psi at 3500rpm before. now all of the sudden it just feels like you hit a brickwall when you hit 3k in 5th it just doesnt wanna go .... its like it farting? is that fuel cut? we went the non seq turbo becuz no matter what we tried the second turbo would not kick on!!!!!!! so we tried the poor mans non seq to get the second turbo to kick which it does before it would just die at 4500rpms heheh my friends type R was whoopin on us but anywho after 7k the boost just dies in any gear and in 5th it feels like fuel cut WTF is up with this heheheh
Old May 28, 2002 | 10:26 PM
7-sins's Avatar
thats not paint....
5th gear is poor with non-sequential under 100. Is it only in 5th, power in all other gears good?
Old May 29, 2002 | 01:16 AM
Eep's Avatar
Eep
brap
It does it sometimes in 3rd and 4th, but all the time in 5th
Old May 29, 2002 | 02:17 AM
7-sins's Avatar
thats not paint....
Maybe it's fuel cut. I know fuel cut in the Power FC to be heavy jerking back & forth. What kind of mods do you have including ECU?
Old Jul 3, 2002 | 07:35 PM
try unplugging you black battery cable and holding tyhe brake for 20 sec, then that will reset you ECU
Queppa
Nov 18, 2024 03:47 AM
Th0m4s
Feb 26, 2019 02:04 AM
sherff
Feb 24, 2019 12:09 PM
