Who uses Water Injection?
Old Apr 17, 2009 | 04:31 PM
goreify's Avatar
40k worth of fail
So with all the threads on water injection, I thought it would be proper to make one to find out who is actually using it. If you are using it, specify what brand it is, which unit/type, any specifications you think are necessary, what you like about it, what you dont like about it, and most importantly, the price of your setup. Also, please include your engine setup (estimated power level etc) to give a better idea of what youre working with.
I'm hoping this can transform into some sort of water injection buyers guide for those who are interested (including myself). There are a variety of kits on the market ranging from $500 to $1500+, so finding out who uses what, and whats working for them would definitely be helpful in deciding which route to go.
When posting include as much useful info as possible and maybe even a few pictures would be helpful, lets see em!
Old Apr 17, 2009 | 07:29 PM
sen2two's Avatar
Rx2 > FD
well, i havnt actually used my kit yet, but im currently installing it. its very easy, but also basic...
but brand new from coolingmist.com its only $199.00!!!!!!!!!! cant beat it. i like it very much. but like i said, i havnt actually used it yet. so we'll see if i keep liking it...
Old Apr 17, 2009 | 10:03 PM
Dudemaaanownsanrx7's Avatar
wannaspeed.com
I'm using water injection. Its similar to the rice racing preturbo kit. Uses boost pressure instead of a pump it has a peak flow currently around 380cc. I made it myself for around $100.
Old Apr 18, 2009 | 05:38 AM
AnthonyNYC's Avatar
Stay tuned...
Brand - Cooling Mist
Kit - cheapest one available, their website has it for under $199
HP - 600HP (10.3@139MPH)
I use water on the street and 50/50 at the track for boost levels 30-35 psi. I don't use pure methanol. I tune the car with E85 and add the water/meth to cool things down and I also run a large intercooler.
I like cooling mist for their support. Sure you can spend a ton more or make your own but I decided to go with the cheapest setup cooling mist has and it's been working well for over a year with no issues and no failures.
Anthony
Old Apr 18, 2009 | 12:42 PM
goreify's Avatar
40k worth of fail
Anthony
awesome info.
are you able to adjust the amount of pressure on this kit to your liking?
what are you using for a tank?
where did you mount your pump?
Old Apr 18, 2009 | 12:48 PM
sen2two's Avatar
Rx2 > FD
im guessing anthonyNYC bought the same kit as i did. the basic kit for 199.00 is NOT adjustabe. as soon as it turns on...its on at full power and stays there. but you can adjust it to its activating PSI.
hey AnthonyNYC, since i have the same kit maybe you could help me out. where are you injecting at? why still running an intercooler? what PSI do you activate it? any tips would help....thanks
Old Apr 18, 2009 | 12:54 PM
4CN A1R's Avatar
sleeper
you use just 100% distilled water in the windshield washer tank for the street right?
Old Apr 19, 2009 | 01:55 AM
goreify's Avatar
40k worth of fail
id like to know also
Old Apr 19, 2009 | 04:50 AM
sen2two's Avatar
Rx2 > FD
you can use whatever you want on the street. but it gets kinda pricey if your wasting alchohol in the street all the time... you can get distilled water from walmart for 25 cents a gallon. but if you go from a meth/water mix to just water. you will need to have a seperate tune you can switch between.
Old Apr 19, 2009 | 09:08 AM
rotorpsi1's Avatar
series 2 rx7
13bre cosmo engine built by me
stock mazda 2mm apex seals
rice racing water injection kit - $800 currently - pnuematic system - no pumps - easy to fit.no hassles all parts supplied except tank.
plain tap water in tank
550.9rwhp on 24psi on shell v power 98 octane pump fuel
its the perfect system.
its there purely for combustion temp control,not intercooling or anything.and egts are perfectly managable even at this pwoer level.im still at sub 900degC egt even with 550rwhp.
its THE BEST system u cna get and he sets it up b4 u purchase it aswell.
Old Apr 20, 2009 | 02:53 AM
AnthonyNYC's Avatar
Stay tuned...
awesome info.
You cannot adjust the pressure on my kit. For what I use it for it works well. My wastegate spring is 20-21 psi so I never see less than that on the street so for me, the basic kits works great. I have the tank and pump mounted above my intercooler.
It comes on about 15 psi and have dual nozzles mounted in the greddy elbow. I don't buy into not running an intercooler but that's a whole other debate. Why eliminate one for another when you can have both. I ran 30-35psi all last year and had about twenty or more 10sec passes on the setup with no issues so it works well for me. Keep in mind I also run E85 so I feel I have the best of all three worlds right now lol.
I use it the same way.
I use regular tap water. This past winter I used a mix so things don't freeze.
Old May 16, 2009 | 09:29 PM
rotorpsi1's Avatar
i tested my car today.
on street tyres runs 12.244 @130.25mph on pump fuel with water injection.
60 ft - 2.16
660 - 8.3 @ 101
0-100 - 4.5 ( no grip)
100-200 - 6.9 with 2 gearshifts
not bad on street ,with street tyres,on pump fuel on 22.5psi boost.
need grip dammit.
Old May 16, 2009 | 10:07 PM
WaachBack's Avatar
Finally Knows
Not trying to dog you or anything, but 550rwhp is more then enough for 10's. Low 11's without slicks.
Old May 16, 2009 | 10:08 PM
WaachBack's Avatar
Finally Knows
I use tap water.
Old May 16, 2009 | 10:40 PM
rx72c's Avatar
Top Answer: 1
I am tap water as well.
Rotorpsi1s car with slicks at a track and proper driving will run 135mph+
His setup is awesome.
His problem is powerband im pretty sure. If he wasnt such a chicken he would lift the rev limiter another 500rpm and it would be heaps better.
Jasons tune is so mild it isnt funny.
Their is so 600rwhp in that tune on a descent dyno and cleaning it out in the top end all the way to 8700-8900rpm and watch the mph go through the roof.
COME ON JASON> GROW THE TESTIES AND DO IT!
Old May 16, 2009 | 10:41 PM
rx72c's Avatar
Top Answer: 1
Another thing i will add. Jasons car was tuned to 550rwhp on 25psi.
On the road its going 22-23 so he isnt using all the power.
Put more boost into it CHICKEN!
Old May 16, 2009 | 11:02 PM
mike_merryguy's Avatar
suck me beautiful
I just finished my kit, supercharged FC, it only gets to about 5 PSI, but that is overcoming 20 vac so not to bad... ( i know i know WEAK but its an n/a fc supercharged, and sounds sick and is fun...)
anyway I have the 199 coolingmist kit as well, I put the tank (1gal) and the pump in the spare tire area, tire is under luggage straps, it comes with a relay and a boost switch, all wired up and comes on at about 1PSI, I also installed a green light in line with the pump (off the relay) so the light comes on when the pump is pumping, lets me know its working, I also have a red light that I will tap into the low fluid indicator when I get it (ordered that today)
Today was the day for testing, just put the lights in and adjusted the boost switch, put the light in so that I can see from the boost gauge where the thing comes on, also for peace of mind... not sure how well it works, I don't have a IAT gauge or anything but I am sure it is doing its job
I am running distilled water only, in so cal so no worry of freezing...
I'll snap some pics in the AM
Old May 18, 2009 | 02:08 AM
rotorpsi1's Avatar
guys i dotn think u understand what it takes to run that time on the street on normal tyres,normal pressures,everyday boost,unprepared rough bitumen.
its ****** hard with rxd and solid axle and 225 tyres i can assure u.
yes,at track it will go 135-140 somewhere,who knows i may go out again and improve that time again.****,its done 12.2@117 on 12psi b4 my plans are to go out and retest it on 14-16psi so its not so overpowered in the lower gears.
to give u an idea its doin 12;s bcos its only doing 2.2 60 foots,this same car and tyre setup has done 1.78 at strip on first attempt,u do the maths
also,i have tested 1000's of cars over the years from evo's to gtrs to gtir's to skylines to silvias all varying on power from 300rwhp to 500+rwhp.
the only car in 6 years to beat this time was hks built 2.8L t51r r32gtr on 21psi and it only did 10.7@128mph with a fuill 400m of full grip acceleration,im doing 130 on same pice of road rwd pedalling it to 100kmh.
dont worry,heaps left in it yet
Old May 18, 2009 | 05:49 AM
rotorpsi1's Avatar
yeah im going to setup my afr logger this week and log the mixtures and see if i can pump another few psi in up top and clean the afrs up again/take 1 increment of fuel out up top to clean it out at 23psi.
i would like to see a neat 24/25psi and 10.5afr instead of 22-23psi and 10.0-10.4afr.the lack of boost is causing slight misfire way up top above 7500rpm and over 160kmh.
i will point out though,unlike drag cars,i can run 12.2@127-130mph off ANY set of lights or intersection should i be craxy enough to want to.
no drag strip or race fuel or vht or slicks or retunes needed.
thats what im happy about,its usable power thanks to the w/i and toyos.
Old May 18, 2009 | 07:05 AM
suck me beautiful
some pics,
first we have the nozzle, in retrospect I wish I would have put it after the BOV, it mufffles the sound sometimes... oh well
next we have the pump and tank, its in the spare tire area.. neat and easy..
and last here are some status lights, red for low fluid, green for injection..
these lights are hudge, radio crap shack was out and parts store had very very big ones, one day I will replace them...
Old May 18, 2009 | 01:33 PM
SirCygnus's Avatar
whats going on?
I baught the cooling mist kit and was 100% unsatisfied with the controller and cooling mist in general.
the controller has controls that stick out too far and with any nudge can be bumped.
also, they dont lable their nozzles. so i just slapped the smallest one they gave me.
i dont recommend getting a kit.
i got a controller from labonte motorsports and have been 100% happy with it. i need to redo my setup and put it inside the engine bay. currently its in the storage bin and im sparying filtered tap water pre turbo.
s4t2 with NA s4 rotors, bnr stage 1 with haltech e6x. 550 bottoms and 1600's on top.
Old May 18, 2009 | 04:58 PM
David H's Avatar
FYI, You can lock the ***** in place on that controller so that if you move the ***** it will not change the setting. In the instructions it tells you the small nozzle is 380 cc the large is 760 cc.
Old May 18, 2009 | 06:08 PM
rx72c's Avatar
Top Answer: 1
Move your jet to pre turbo.Post turbo is no were near as effective.
And honestly. Distilled water? are people on this forums serious?
Old May 18, 2009 | 08:07 PM
suck me beautiful
dude i live in San Diego.. when I fill my coffee pot it takes 5 minutes to clear up.. and if I spray that on my car.. white spots EVERYWHERE that take forever to scrub off with windex and PP towels, tastes like crap and well you get the point so YES distilled water....
Old May 18, 2009 | 08:26 PM
I'm injecting windshield wiper fluid after 9 psi, Aquamist 1s kit. Car runs like a champ, I was ripping around yesterday at 19 psi on 93 octane pump fuel, the car loved it based on knock, EGTs, and lack of traction
https://www.rx7club.com/showthread.p...=aquamist+pics
