clutch
Old Apr 17, 2009 | 09:13 AM
fast2g's Avatar
DEADLY EXHAUST LEAK
clutch
okay so the clutch is brand new on a 90 rx7 stage 2 f1 racing. the problem is when you start taking your foot of the clutch when the car starts moving the whole car shakes violently. but when its driving it stops. i've been told that since the clutch is new and the flywheel is resurfaced it needs to be givem some time to seat in.
Old Apr 17, 2009 | 02:41 PM
Aaron Cake's Avatar
Engine, Not Motor
Is it a sprung clutch or is it a puck style unsprung? If it is the 2nd one, then it will take a LOT of practice to get moving smoothly.
Old Apr 20, 2009 | 04:11 PM
wakazz's Avatar
Bay Area Rotary
Ya dude i have an aggressive clutch too and well ya it will shake ur car if you slip it too much... if you feel that try letting it go completely.. generally you want to avoid slipping those type of clutches since they are meant for racing and not daily driving.
Old Apr 23, 2009 | 01:49 PM
fast2g's Avatar
DEADLY EXHAUST LEAK
so even when your getting the car starting to move..(taking out the clutch a little... it shakes on the stage two) let me know if that is what you mean if its that then thanks. that mean its gonna have to be driven a little more agrressive right.
Old Apr 24, 2009 | 01:08 PM
Aaron Cake's Avatar
Engine, Not Motor
Unsprung clutch will shudder and grip as soon as the disk comes in contact with or looses contact with the flywheel/PP.
Old Apr 24, 2009 | 01:56 PM
fast2g's Avatar
DEADLY EXHAUST LEAK
Talking
this is the clutch i got
Old Apr 25, 2009 | 09:56 AM
Aaron Cake's Avatar
Engine, Not Motor
Did you resurface the flywheel when you installed it?
Old Apr 27, 2009 | 01:47 PM
fast2g's Avatar
DEADLY EXHAUST LEAK
yes it has been resurfaced
also i drove the car yesteday for a good long distanced and it shifts good and theres no problem.. the only thing is that when taking off it shakes but then it stops so im guessing its just the new clutch setting in.
thanks for the help
Snoopy FD
Oct 13, 2016 06:12 AM
risingsunroof82
Sep 9, 2015 08:06 PM
