suggestions on removing vdi valve?
Old Apr 16, 2009 | 06:57 PM
ultrataco's Avatar
r o t a r y
Question suggestions on removing vdi valve?
My car is a 91 s5 n/a.
I'm trying to remove my vdi valve to inspect it and replace the gasket, but it's stuck on with some sort of gooey black sealant instead of a proper gasket, and it doesn't want to come off. Any ideas?
Old Apr 17, 2009 | 11:08 AM
another7driver's Avatar
Listener
sounds like average rtv/silicone sealant. cut/scrape it off with a utility knife if you can manage not to damage the part you're working on. Be sure to clean the mating surfaces thoroughly when you replace the part.
Old Apr 17, 2009 | 08:48 PM
ultrataco's Avatar
r o t a r y
Ok, thanks. That did it. I scratched it up a little bit getting that stuff off, but I think it's ok.
SakeBomb Garage
SakeBomb Garage
May 11, 2020 10:04 AM
risingsunroof82
Sep 7, 2015 01:11 PM
Tem120
Sep 7, 2015 09:53 AM
Nosferatu
Sep 5, 2015 02:13 PM
