My first FD. Can I reach my HP goals on Efini twins?
Old Apr 16, 2009 | 10:44 AM
Renesis_Nemesis's Avatar
Its been a long time coming, but I'm finally able to get my first FD. I'm looking for a quick street car, not a crazy track car. However, my last project was an Eclipse GSX running a GT30R turbo at 25 psi....probably up around/over the 350 awhp range. Of course you get used to it and always want more. With a street port engine, and all supporting mods, including meth injection, can I get 350-400 rwhp on 99 spec Efini twins? sequential or non-sequential?
Old Apr 16, 2009 | 05:29 PM
dgeesaman's Avatar
350rwhp is pushing it for Efini twins. The Efinis have basically the same compressor performance at the top end as the stock turbos. Running any stock turbos in the 350-400rwhp range will burn them up early. 250-350 is where I'd run stock turbos.
If you want to push the 400 mark with reliability go with single turbos or BNR stage 3s.
I'm not a fan of nonsequential unless you're going to do the full conversion, grinding/porting/welding doors shut and stuff, or unless your sequential simply isn't working and you don't want to fix it.
Dave
Old Apr 17, 2009 | 07:06 AM
With my eclipse, to get the low end response I wanted from a small turbo I had to push the limits of efficiency...and pump gas, with 22 psi and was forced to run methanol. I just love the response of the twins since its not the torquiest motor by design.
toplessFC3Sman
Mar 20, 2018 01:54 PM
HalifaxFD
Canadian Forum
126
May 9, 2016 07:06 PM
sinistersam
Sep 13, 2015 07:17 PM
