Sponsored by: CARiD
Rebuild started fine, ran for 30 mins, now it wont start!
Old Apr 14, 2009 | 08:56 PM
Aeka GSR's Avatar
I've built a few engines and have had them flood on me, but nothing like this.
I put a half bridge 13brew in my FD that I built and it started on the first try, ran great actually. I was going over the usual checks and letting it idle with the occasional dickin' around with brapping the throttle. I even took it around the block.
I shut it down and started it several times that day, getting it up to operating temp every time. It never got bone cold between starts.
The next day I went to start it up and it didn't even try to start. I let it roll out of the garage and I gave it a pop from the clutch followed by some cranking, it burped and rattled for a second and died. I then had my wife push me down the street, hah, and it fluttered and tried to start but it never caught.
So I did the old fashioned way I've been accustomed to: pulling the leading plugs, cranking and cranking with the EGI fuse out till she puffed no more, put MMO in the plug holes and put a different set of plugs in and tried to start. NOTHING! I did this several times already and have grown upset and frustrated. This trick always worked like a champ for me.
I'm thinking about bringing a friend over with more muscle than my wife so we can get it rolling really good and try a good pop start in 2nd gear. It seems the only time it tried to start was when I got it rolling.
I'm afraid of a pull start method since I've heard of people spinning a bearing, so it would be nice to avoid that, not to mention I think I would need to pull my bumper for that crap.
Anything I could be missing?
Old Apr 15, 2009 | 12:05 AM
Aeka GSR's Avatar
push start failed. Ran that thing as fast as my friend's and my feet could move, nothing. We tried 4 times before giving up, tired, and sad.
Old Apr 15, 2009 | 02:23 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
It is a new motor, they will give you hell sometimes.
I would check these first
Fuel Pressure
Fuel Injectors
Spark to L and T
Compression, Just Check
then
PULL START IT
How would pull starting it cause a bearing failure? The oil pump is running. If you mean a trans bearing failure then yes if it was a Automatic
Old Apr 15, 2009 | 09:21 AM
Aeka GSR's Avatar
if you dump the clutch while rolling at a good speed you will most likely bring the rpms up high before oil has had a chance to get to the bearings. I know of one person who grabbed a bearing, but hes rebuilt and raced so many engines that one is bound to fail.
I've got all of the above listed except I haven't done a comp test. Not really worried about it since it did run. I think im going to get some 50 weight in there and start it with some ether. Hopefully I'll have an answer this evening.
Old Apr 15, 2009 | 08:31 PM
Aeka GSR's Avatar
OK I got it started again.
I didn't even pull the plugs.
I cranked it with the fuel pump disconnected
Poured straight 40 weight in the intake manifold
Sloshed it around a few turns
Shot some starter fluid in the manifold
Plugged the pump back in
Fired up no problem.
BUT OH GOD THE SMOKE! It is acting like a shot oil control ring it smokes so bad. I drove it out of the neighborhood and parked off the side of the road and let it run for about 5 mins with no signs of it letting up. Some lonely old lady pulled off the side of the road to see if I was ok and we talked about the housing market while my car blasted smoke everywhere.
I really hope this is just all the oil in the intake and exhaust that I've been dumping in burning off because it would suck for an oil control ring to **** itself even though it ran smokeless the other day.
Old Apr 15, 2009 | 09:05 PM
Aeka GSR's Avatar
I let it sit for 30 mins or so and fired her up again. The smoke continues for about a minute then vanished. Either the manifold was so coated in oil that when I let it sit all the oil ran into the engine OR an oil control seal or ring was still seating and it needed a heat cycle which I've never heard of.
Old Apr 15, 2009 | 11:28 PM
Aeka GSR's Avatar
Drove it around a while, got gas, got the idle down under 1400 so it seems to be getting better compression as I was only able to get the idle at 1900 when I first started it.
Old Apr 19, 2009 | 06:51 PM
-xlr8planet-'s Avatar
I has an emblem
I feel you
Im trying to start a half bridge 12a
Old Apr 19, 2009 | 07:51 PM
TEDDER1's Avatar
Ive pull started my FD several times. I just leave it in first and have someone pull it with my blazer. It works every time.
Old Apr 21, 2009 | 03:09 AM
WaachBack's Avatar
Finally Knows
That's normal, the motors compression should improve in it's break in period a little.
alphawolff
Nov 17, 2015 05:57 PM
PhillyFC
Aug 21, 2015 06:36 PM
86glxNA
Aug 18, 2015 03:33 PM
