What is causing my car to die?
Old Apr 14, 2009 | 08:44 PM
mkv105's Avatar
I have owned my rx7 for over a year. When I drive my car around for a about an hour it starts to die when I come to stop lights and stop signs. Ive checked fluids and looked for leaks and everything is fine. What would cause my car to just die when warmed up.
Old Apr 15, 2009 | 01:59 AM
Rx7_Nut13B's Avatar
Red Neck Tony Stark - C2
Possible,
To low of a Idle
TPS out of adjustment
Dash-Pot not working anymore
Old Apr 15, 2009 | 05:23 AM
Go48's Avatar
Check compression.
Old Apr 15, 2009 | 11:50 AM
RotaryRocket88's Avatar
Top Down, Boost Up
Likely idle speed. FSM or Haynes manual will show you how to adjust it.
Basically, it involves the TPS, variable resistor, air bypass screw & throttle stops.
Old Apr 15, 2009 | 11:22 PM
mkv105's Avatar
thanks everybody
alphawolff
Nov 17, 2015 05:57 PM
LunchboxSA22
37
Oct 26, 2015 10:53 AM
rotor_veux
Aug 23, 2015 09:06 PM
