weld wheels on a second gen
Old Apr 14, 2009 | 08:22 PM
sen2two's Avatar
Rx2 > FD
just to make sure before i buy them...
weld wheel fitment for a second gen is 4.50 lug pattern with 4 1/2 inch back spacing?
also, im looking for pictures of a second gen with either draglites or prostars. trying to decide between the two... 15x8 out back and the 15" skinnies up front.
Old Apr 23, 2009 | 11:54 AM
bs250r's Avatar
I too would like to see a fc with welds. How large of a rear tire can you fit on a 15" weld with stock fenders. Thanks
Old Jan 27, 2013 | 02:01 PM
rx7355's Avatar
hey guys, i may be able to shed some light on your requests for weld wheel fitment.
i have a 91 rx7 that i am also putting weld prostars on and had a hard time finding what would fit. this is what i have come up with.
15x3.5 prostars on the front with the only offset option of 1.375 or something like that. they do sit flush or stick out slightly due to the off set and if u have t2 brakes u need to run a spacer up front. as for tires i havent figured that out yet, i plan to run 24 or 25's.
as for rears. 15x8 with 5.5 backspacing and 255/60/15 i believe is the biggest u can go maybe 265 or 275 with some rolling fenders and what not.
now i haven't had the opportunity to test fit anything ....this is just what i had gathered from other people and sites.
hope it helps
also here is a picture of someone elses car from norotors.com .
whizzybang
Naturally Aspirated Performance Forum
21
Feb 10, 2017 12:08 PM
KAL797
Test Area 51
Aug 11, 2015 03:47 PM
