Sponsored by: CARiD
Leading spark issue
Old Apr 11, 2009 | 12:28 PM
jaggermouth's Avatar
Will TIG for 20b
Leading spark issue
Well, I put it up in the Haltech forum, but maybe they don't know and maybe it isnt related to the Haltech directly.
ANYWAYS!
This is regarding the stock FC coils. While I'm cranking, the leading coil SPARKS right off the bat, cranks maybe 10 or so times and then sparks again.
Not sure if its my trigger wheel (Its an FD engine swap) or something else, but I cant really check and lock the timing when I get 1 spark ever 10 cranks.
Any ideas? I checked my wiring, and I put a different coil on.
Old Apr 11, 2009 | 10:05 PM
bumpstart's Avatar
talking head
ANYWAYS!
clearly the haltech is not seeing the trigger or home so well
-- if it see's a random trigger pulse,, it will put out a sequence of sparks in the expected order,, and wait till it sees the home pulse to start the sequence again
( which clearly isnt happening ,, so then you next see a spark when the coil overloads and collaspes when you stop cranking )
its something to do with the polarity of the incoming home or trigger signals
( so that the trigger edge goes the correct way through the internal reluctor adapters )
or RFI noise from alt, starter or leads corrupting that signal
( ie,, needs the filter gain settings played with )
OR
-- its a common problem caused by the inherent polarity of the mazda coils wanting a reversed from the norm trigger edge output to make them work
ie
they want falling edge, constant charge, coil dwell time 3.25 - 3.75 ms
Old Apr 11, 2009 | 10:46 PM
Will TIG for 20b
So the shitty wiring on my trigger and home wouldn't help, eh?
Im trying to scout out a used harness locally so I can fix them, but what you said makes a ton of sense, I was expecting the home or trigger to be the issue.
Thanks a lot! I was hoping for any answers and Im glad you gave a nice one
rgordon1979
40
Mar 15, 2022 12:04 PM
ZacMan
Sep 19, 2015 09:20 PM
ZaqAtaq
Sep 5, 2015 08:57 PM
Steven_McKinley
Sep 5, 2015 10:48 AM
