Haltech E8 WB Closed loop PID settings?
Old Apr 10, 2009 | 06:37 PM
IAN's Avatar
IAN
Rotary Reborn!
Does anybody have a recommended proportional and intergral settings for a closed loop control on the E8.
No matter what I do it always pegs it to the max limit of reduction or addition. (mine is set to 10%)
I tried to set it up for two hours on the highway. My target a/f map is set. It should be relatively easy to set up. Before I upgraded to 1.89 it appeared to work properly. Also there is nothing wrong with my wideband hook up or operation of the wideband.
I basically set everything to 0 and just increased proportional until i see the it hit setpoint and oscilate. It never hit anything. At 100% proportional band it would just sit at 2% correction and not even make it close to the target setpoint. When I set the intergral to .10 it slowly would increase to 10% and sit there.
It appears as if it does not work at all. I was going to use the E8 for closed loop boost response but it doesn't appear to work at all in closed loop??
Anybody with the E8 V1.89 soft actually have a working closed loop?
Ian
P.S. Yup I am the one that was fighting with the autronic 500R/E8 install. it all works well know. 300km and counting.
Old Apr 10, 2009 | 08:12 PM
IAN's Avatar
IAN
Rotary Reborn!
Ok, Delete this thread. I am an idiot. When I upgraded to 1.89 I must have missed that it when from wideband a/d 2 to wideband into 02 input.
Anyhow when I get it tuned satisfactory I will post the settings.
thanks,
Ian
Old Apr 13, 2009 | 10:04 AM
Claudio RX-7's Avatar
EFI Tech Wannabe
Rule of thumb for setting the PID's is first and foremost the Derivative is ALWAYS ZERO.
Then, bring the Proportional upwards in 5% increments until the AFR start to oscillate. Then start bringing up the Integral until the oscillation is canceled out. Usually the Integral will be approximately half of the Proportional.
Old Apr 13, 2009 | 10:06 AM
C. Ludwig's Avatar
www.lms-efi.com
FWIW I have had great luck with the default values.
Old Apr 13, 2009 | 06:24 PM
IAN's Avatar
IAN
Rotary Reborn!
Awesome. Played with it for a while. Sort of hard seeing the response on the wideband display. Maybe with some datalogging it will be easier. Either way it appeared to oscillate a bit regardless of settings. Probable due to my tune?
My settings were Proportional 30% and intergral .25%
CaptainKRM
14
Aug 26, 2015 09:52 PM
