Sponsored by: CARiD
Engine restorer good for rotaries????
Old Apr 7, 2009 | 07:24 PM
mdeserteagle50's Avatar
i can see the light!!!
VA Engine restorer good for rotaries????
I have been dealing with this stuff for years....I have had mixed feelings on this product.(works on some engines, and not so well on other engines) I have used it only on piston engines. I decided to endure the ridicule from some people and ask if this stuff is good for a rotary??? Like I said, this stuff has worked well on some engines, and did absolutely nothing on others. For those that dont know what this stuff is, it is supposed to restore compression in the cylinder walls of tired *** piston engines......I had also been told that SEAFOAM does similar actions as this product claims.
So, I will endure the ignorance in search of a positive/ correct answer.....Engine restorer good for rotaries????-restore-left-1.jpg
Old Apr 7, 2009 | 09:23 PM
t-von's Avatar
Rotor Head Extreme
You know, I've actually been curious about this myself. I don't think it would harm the engine. I would experiment myself on my 91 NA vert but my OMP isn't working.
Old Apr 8, 2009 | 09:20 AM
Ive been thinking of experimenting on my n/a DD, but just wanted to get some info from a few rotary veterans....I dont think it would do any harm, but at the same time the rotary is sensitive and dont want to harm a perfectly good running engine......
Old Apr 8, 2009 | 12:37 PM
GOT-RTRY's Avatar
All Blacked Out
i used engine cleaner (not sure if it was the same band) in my n/a and the next day i was blowing smoke out my exhaust like mad! now i have a TII
Old Apr 8, 2009 | 04:32 PM
Thanks GOT-RTRY, but that is exactly NOT what I want to happen. Does anyone have ANY insight into this?????????
Old Apr 8, 2009 | 08:26 PM
2slow4stock's Avatar
The waiting game......
It cleans up the internals and on an old engine it could be good or bad.. Mostly bad...
I wouldn't if I were you... But that's just me.
Old Apr 8, 2009 | 08:58 PM
ericgrau's Avatar
Clean.
Eh, I wouldn't bother. Oil additives especially tend to be bunk. That sounds like it might be some super-viscous stuff that slows down some leaks temporarily but creates excessive wear in the long run. Try heavy weight oil like 20w50 if you have problems like that, but don't go any heavier.
A lot of people do swear by sea foam and have seen it clean out old engines. But such things aren't necessary or helpful on a good engine. If you have an old neglected engine you could try sea foam but if it hasn't gotten bad yet then basic scheduled maintenance should be plenty.
Old Apr 10, 2009 | 02:29 PM
Thanks for the info guys..........Any rotary tricks for getting a t2 to run again after its warmed up??? I can get it to crank and run when its cold, but if its been warmed up and I try to start it again, she just floods.....Any help????
Seaweed
Aug 16, 2015 11:46 AM
