remove fuel cut chip?
Old Apr 6, 2009 | 09:10 PM
kevyn_rx7's Avatar
I'm charming
i just recently bought my rx7. the guy who owned it before me.. well, to say the least, he did some pretty dumb stuff to the car... i won't go into details at this time..
anyways, my question was about the fuel cut chip he had installed. i'm not sure i like the sound of it. i was reading about the racing beat fcc it sounds like it's just bad news. should i just go ahead and remove this thing or what?
thanks
Old Apr 7, 2009 | 09:04 AM
Aaron Cake's Avatar
Engine, Not Motor
Just remove it from between the harness and the pressure sensor.
Note that when you do, the car will cut all fuel to the rear rotor if the boost passes 8.6 PSI. This is to avoid an overboost situation.
Old Apr 7, 2009 | 10:36 AM
RotaryRocket88's Avatar
Top Down, Boost Up
It's a fuel cut defenser. And like Aaron pointed out, it's there to stop the ECU from cutting fuel above stock boost levels. That being said, while it will let you run more boost, it will also fool the ECU and cause timing to no longer be pulled properly when under pressure. So if you don't plan on running boost levels over stock, removing it will allow timing adjustments to be made like they should.
Old Apr 7, 2009 | 05:39 PM
kevyn_rx7's Avatar
I'm charming
ahhh i see. i guess i didn't quite understand what i read before.
i suppose i'll leave it in there then... i do plan on boosting above stock.
thanks for the help
Old Apr 7, 2009 | 07:03 PM
Top Down, Boost Up
Keep in mind, you will need to add fuel before taking boost over say ~8-9psi. And at that point, you'll need something to control the bigger injectors. An Rtek chip will be far more timing friendly than the FCD, and solve the injector control problem. Details here: www.pocketlogger.com
Old Apr 7, 2009 | 09:07 PM
kevyn_rx7's Avatar
I'm charming
would a turbo timer/boost controller be a better option than the fcd? i guess i'm still not quite getting it :/
Old Apr 7, 2009 | 10:59 PM
Top Down, Boost Up
Completely different things.
Turbo timers are not needed. Boost controllers adjust when the wastegate opens to allow you to see higher boost levels. The FCD just keeps the ECU from cutting fuel at 8.6psi by altering the signal from the boost sensor. The Rtek chips for the stock ECU remove the fuel cut code altogether, so there is no "fooling" going on.
Old Apr 8, 2009 | 06:39 AM
kevyn_rx7's Avatar
I'm charming
okay i'm pretty sure i'm getting it. correct me if i'm wrong... i should just say forget the turbo timer and fcd and go with the rtek chip?
Old Apr 8, 2009 | 07:15 AM
ncfc3s's Avatar
You should take time and read up on the performance section before you start tinkering with your new purchase. Congrats.
Old Apr 8, 2009 | 10:12 AM
Top Down, Boost Up
The Rtek is a much better route.
But as mentioned above, give it a little time before you start modifying the car. A good knowledge of what's going on will keep it safe. A rotary turbo is easy to blow, if you don't do it right.
Old Apr 8, 2009 | 06:29 PM
kevyn_rx7's Avatar
I'm charming
so i've heard.
a friend of mine/fellow rx7 owner (n/a) is kind of the rx7 guru around here so a lot of my questions are directed to him.
i'll start reading up some more. thanks for the help. much appreciated.
Monsterbox
Jul 29, 2022 10:48 PM
alphawolff
Nov 17, 2015 05:57 PM
armans
Aug 15, 2015 09:08 PM
