Haltech Platinum Sport Cheat Sheet
Old Apr 4, 2009 | 10:06 PM
farberio's Avatar
NASA-MW ST4
I decided to go through all of my connections before I touched the car, so I put all of my stuff in an excel sheet.
I used the Hitman Install page as a base and adjusted for the new platinum series. All of the wiring came labeled from haltech so it was pretty easy to figure everything out, a couple of questions were answered by Chris Ludwig and this is what I have come up with. I also tried to make notes where relevant and reference a thread in case there are additional questions.
Good thing to print out and have with you during install.
This is all based on my install, which is an n/a, so it doesn't cover everything.
File Type: zip
Old Apr 5, 2009 | 05:58 AM
C. Ludwig's Avatar
www.lms-efi.com
Looks good. Should be stickied.
Old Apr 21, 2009 | 07:20 PM
C. Ludwig's Avatar
www.lms-efi.com
Just a note on this. PWM 1 should always be reserved to drive a tach. It is the only output that can run the positive voltage pull up that a tach needs. Unless you are out of outputs and need to use it for something else I'd recommend just not using it if you're driving your tach with a coil output or something similar. This way, in the future if you need to drive a tach with the ECU, PWM will be available and it will be easier to wire it.
Coochas
44
Nov 5, 2019 11:08 PM
wstrohm
24
Oct 5, 2015 11:35 AM
TeamRuffRacing
Sep 30, 2015 08:13 PM
