Would you buy....
Old May 26, 2002 | 07:57 PM
Want2race's Avatar
Bigger and better things
Would you buy....
a midpipe/highflow cat pipe ?
It would be flanged where the stock ends are ( obviously) and have 2 bolts on either side. Making the swap from a highflow cat to a midpipe simple and requiring less then 10 minutes.
I found a place that can do a 3" mandrel bent pipe for $125 and I can get highflow cat cartidges for around $225 ( high heat.. so rotary OK)
Total cost would be $400 even and you WILL pass emmisions and 10 minutes later ( letting it cool no doubt) your back to your midpipe and making the big hp!
the advantage of this is a VERY VERY Simple swap betweenthe 2. Thats the objective! To swap between them as quickly and effortlessly as possible. There may be a brace that goes between the 2 end segments to make alignment even easier then before..
And for 5 minute swaps V band clamps will be an option but cost an additional $50/$100.. need to see what they cost each first...
~Jonathan
Old May 26, 2002 | 10:22 PM
skunks's Avatar
I'm a CF and poop smith
I would get a midpipe, but im in hawaii and there is no emmisions laws here!
NoPistons!
SE RX-7 Forum
Dec 7, 2008 04:54 PM
rksti89
Aug 26, 2008 02:44 PM
