using the factory subframe with a 20b
Old Apr 1, 2009 | 01:09 AM
rotorooter93fd's Avatar
YOUR TRIANGLE NIGHTMARE
do i have to cut the firewall to use the factory subframe? do I need to make a new oil pan to clear the steering rack if I do use tha factory subframe? obviously bumpsteer would not become a problem but would I throw off weight distribution or have clearance problems with the hood?
Old Apr 1, 2009 | 05:36 AM
sm0keyii's Avatar
Everyone loves oppai =)
If a FD is what you got, Defined Autoworks has done all the math for you. No cutting required. Yes the pan gets modified a bit, as well as a couple of other things. Check out their thread. https://www.rx7club.com/defined-autoworks-176/defined-autoworks-20b-conversion-kit-644417/
Old Apr 1, 2009 | 11:08 PM
t-von's Avatar
Rotor Head Extreme
Sticking the larger, heavier, and longer engine in the stock location will change the center of gravity. This is because you are moving the weight higher and furthure forward.
sctRota
Old School and Other Rotary
Nov 10, 2015 12:57 PM
