Gas Tank Questions?
Old May 26, 2002 | 08:26 AM
Scracho's Avatar
Gas Tank Questions?
Hey everybody,
I have an 87 TII that has some blatter issues. So I went to remove the old gas tank and I found rust inside the tank. Not chips of rust, but surface rust. I understand that moisture will build inside the tank, but I never thought I would actually see surface rust. Could this harm the gas? Would this cause some issues with my motor?
I went to the wrecking yard and had found one that was mint! When I looked inside thought, it had much less surface rust, but it still had it. Should I buy this one or replace with new? ($450.00CAN New Vs. $100.00CAN Used)
Thanks in advance
Old May 26, 2002 | 06:10 PM
Scracho's Avatar
BMP.... Please HELP!
Old May 26, 2002 | 07:14 PM
Cameljoe's Avatar
You dont want any rust in or outside the tank. I had to change my tank after it sprung a leak. Found a used tank at the junkyard that was rust free. I'd say keep looking.
Tylerx7fb
39
May 27, 2019 12:45 PM
Rotospectre
Mar 28, 2018 03:33 PM
alphawolff
Nov 17, 2015 05:57 PM
sip
19
Sep 7, 2015 03:33 PM
