draining radiator
Old May 26, 2002 | 08:13 AM
ASEmaster's Avatar
draining radiator
Is there a way to do this without making a huge mess? Last time I just pulled the lower hose and mopped up later, but that was someone else's garage now that it's in mine I'd rather not have to take that coolant bath again. Anyone got any tricks? I thought I would pull the block drain first and that might help.
Old May 26, 2002 | 09:19 AM
MIKE-P-28's Avatar
Driven a turbo FB lately?
In the center housing of the block (the one between the 2 rotor housings) atthe very bottom theres a plug, i think its 14mm, put a pan under it that will hold 5 quarts or so, remove the plug , presto antifreeze drain It still will make a small mess when you remove the radiator but maybe a few pints instead of a gallon
Old May 26, 2002 | 09:20 AM
Felix Wankel's Avatar
Super Newbie
My rad has a petcock on one of the tanks.
MidnightOwl
Sep 25, 2015 10:24 PM
