86 rx7 tranny vs 91 rx7 tranny
Old Mar 28, 2009 | 01:37 PM
dodos6999's Avatar
MI 86 rx7 tranny vs 91 rx7 tranny
can anyone tell me if i can replace my stock 86 tranny with a stock 91 tranny without any modifications, they are both none turbo. thanks
Old Mar 28, 2009 | 03:36 PM
Kentetsu's Avatar
Sorry, I just do 1st gens. Someone will be along with the answer shortly though...
Where in Michigan are you? You should check out the Midwest section of this forum, a couple of threads there you'll want to check out if you're interested in meeting other owners...
Old Mar 29, 2009 | 09:37 AM
farberio's Avatar
NASA-MW ST4
You will be fine, but you need to use the transmission crossmember that matches the transmission.
So to put the 91 in the 86 you need to use the 91's (S5) crossmember.
Old Mar 29, 2009 | 06:26 PM
dodos6999's Avatar
thanks guy's but i have one more ? someone just told me that i would have to change out the axle and the starter, I would run into much trouble, just to stick with an 86-88, is this true? thanks
Old Mar 29, 2009 | 07:11 PM
farberio's Avatar
NASA-MW ST4
This 'someone' needs to spend more time on the 7 club because everything he said is wrong.
Old Mar 29, 2009 | 07:39 PM
dodos6999's Avatar
thanks a lot farberio, I'll get the tranny and the crossmember
Old Mar 30, 2009 | 12:07 AM
RadioX7's Avatar
X MARKS THE SPOT
i have a s5 tranny....i was trying 2 sell it cuz i thought it didnt fit so super thanxxxxx!!!!!1
sleepydogz
Old School and Other Rotary
Oct 4, 2015 03:46 PM
DaleJK
Aug 31, 2015 10:19 AM
sYnth.
Aug 19, 2015 06:27 PM
