Cluster switches
Old Mar 24, 2009 | 10:18 PM
Fcninja4686's Avatar
Cluster switches
Are the cluster switches different from 88 convertible RX-7 than from the hatch model?
Old Mar 25, 2009 | 09:37 AM
Aaron Cake's Avatar
Engine, Not Motor
There are several versions of the right side cluster switch that vary based on model. I think 'Verts have their own. The left side switches are basically the same for all cars in the series.
Old Mar 25, 2009 | 10:18 AM
Icemark's Avatar
88 and 89 verts use a different wiper switch than any other models as the top retraction/opening switch is located in the wiper switch assembly.
The headlight switches are the same though.
Old Mar 25, 2009 | 04:28 PM
Would it still work? Or would it cause problems when retracting the top?
Old Mar 25, 2009 | 04:31 PM
Icemark's Avatar
If you are talking about using a non 88-89 convertible wiper switch in a 88-89 convertible, you would not be able to retract the top unless it was a 88-89 convertible wiper switch.
Old Mar 25, 2009 | 11:59 PM
Ok that is exactly what I wanted to know. Thanks for the feedback
