Nubie Transmission question
Old Mar 23, 2009 | 09:18 PM
hoofhearted's Avatar
Photon co-inventor
I saw a 90 GXL tranny today that looks different from what I expected to see. The fins on the bell housing run top to bottom around the front of the bell housing. The gearbox appears smaller (in circumference), to me.
Does this look like a standard S5 GXL 5 speed?
Old Mar 23, 2009 | 09:28 PM
The Spyder's Avatar
Never give up!
Standard
Old Mar 23, 2009 | 11:45 PM
Photon co-inventor
Thank you Marc.
I've got a 'vert 3.90 rear-end that is being converted to a 4.10 lsd.
What needs to be changed to make the speedometer read correctly with the new set of gears? Is there a cog in the tranny that one can change to get the proper mph? I don't know the tire size but they are 16 inch after-market wheels.
Old Mar 24, 2009 | 03:22 AM
The Spyder's Avatar
Never give up!
You are correct. I am not sure which cog you need. Have you got a GPS yet? Easiest thing to do is take a drive and compare the speeds.
_Tones_
May 25, 2021 05:37 AM
Enzo1944
Sep 6, 2015 08:57 AM
