serious help... please
Old Mar 16, 2009 | 07:33 PM
89ntrcptr's Avatar
ok so im trying to figure out the wiring on my 90 rx7... in the pass side kick panel suppose to be a x-15 and x16 connector that connects the front harness to the emmissions harness... prob is according to the diagrams the wire colors and connectors dont match up... when you pull the emmissions harness from the car there is 4 connections insdie the car correct? 2 to the ecu and the x15 and 16.. one connector has 19 wires coming from it on the emmisions side plug and the other has 10 wires coming from it on the emissions side
Old Mar 16, 2009 | 08:03 PM
89ntrcptr's Avatar
did more research turns out i have x-10 and x-11... these harnesses have the wires for the wiper motors and coolant temp? if these are 10and 11 where is x-15 and 16 i thought those contained the wiper motor wires and coolant temp
Turblown
Vendor Classifieds
Oct 17, 2020 03:25 PM
