My New motor mounts
Old Mar 11, 2009 | 03:24 AM
levelzero's Avatar
My New motor mounts
I've been making motor mounts all week and I figured while I was at it, I'd whip up a few sets of the ones I designed for my FC. I wasn't happy with anything I'd seen on on the market and designed something to meet my needs.
The rubber will absorb some of the low rpm/idle vibrations while still drastically limiting engine movement. During the summer/race season I can swap the rubber out for an aluminum spacer and run fully solid. I also pocketed the inside of the large aluminum portion to save weight. Total weight with hardware is 0.70lbs each which is about half of stock.
Old Mar 12, 2009 | 07:45 AM
Andy.S's Avatar
MY SA22C
man these mounts look good.. you said you custom made these would you sale some for a firs gen?? if so then how much get back im really interested in solid motor mounts tranny mount if possible to... thanks.
Old Mar 13, 2009 | 09:36 PM
levelzero's Avatar
Yeah I can make some for the first gens. I'd just have to get my hands on a pair or get the needed measurements.
I just finished installing them and I'm actually quite happy. My passenger side one was shot so it's not a great comparison but at idle there actually less vibration, and my shifter isn't bouncing around any more. At highway speeds it's a tiny bit noisier and just cruising around it was hard to tell the difference except for there is no slop in the drivetrain when stabbing the throttle.
Engaging the clutch is the only time you really notice the vibrations. At about 1500-1750 it gets fairly shakey. Dropping the clutch from 5500 the car just squats and goes with no wheel hop ..... doing a brake stand resulted in some burnt clutch due to the new found traction :S
Old Mar 14, 2009 | 06:51 PM
Andy.S's Avatar
MY SA22C
if you were to make some how much would you charge for them with shipping and all cause i live in atlanta georgia and id like to get motor mounts and ive been looking around and seeing prices thats why i wanted to see how much you wanted for them... but get back at me when you can... thanks
Old Mar 15, 2009 | 07:31 AM
felix_is_alive's Avatar
looks nice .....
Old Mar 16, 2009 | 02:30 AM
levelzero's Avatar
$75 shipped. These are fairly involved to make between the cnc machining the different parts and then cutting the rubber bushings. I could make solid aluminum one much cheaper though as the typical ones are standard bar stock with a hole through them.
Old Mar 16, 2009 | 07:43 AM
Andy.S's Avatar
MY SA22C
Oh. You said you could make aluminum mounts cheaper how much would those be???
