For the people who disabled the VDI!
Old May 24, 2002 | 03:18 PM
Samps's Avatar
I was just trying to learn something on HSW.com and I came across this interesting little bit of info that describes exactly why the VDI is important and why it helped out the series 5 motor so much. Here it is; copied and pasted:
Question
I've heard about tuned intake runners for car engines that provide a kind of turbo-charging effect. How do they work?
Answer
The intake system on a four-stroke car engine has one main goal, to get as much air-fuel mixture into the cylinder as possible. One way to help the intake is by tuning the lengths of the pipes.
When the intake valve is open on the engine, air is being sucked into the engine, so the air in the intake runner is moving rapidly toward the cylinder. When the intake valve closes suddenly, this air slams to a stop and stacks up on itself, forming an area of high pressure. This high-pressure wave makes its way up the intake runner away from the cylinder. When it reaches the end of the intake runner, where the runner connects to the intake manifold, the pressure wave bounces back down the intake runner.
If the intake runner is just the right length, that pressure wave will arrive back at the intake valve just as it opens for the next cycle. This extra pressure helps cram more air-fuel mix into the cylinder -- effectively acting like a turbocharger.
The problem with this technique is that it only provides a benefit in a fairly narrow speed range. The pressure wave travels at the speed of sound (which depends on the density of the air) down the intake runner. The speed will vary a little bit depending on the temperature of the air and the speed it is moving, but a good guess for the speed of sound would be 1,300 feet per second (fps). Let's try to get an idea how long the intake runner would have to be to take advantage of this effect.
Let's say the engine is running at 5,000 rpm. The intake valve opens once every two revolutions (720 degrees), but let's say they stay open for 250 degrees. That means that there are 470 degrees between when the intake valve closes and when it opens again. At 5,000 rpm it will take the engine 0.012 seconds to turn one revolution, and 470 degrees is about 1.31 revolutions, so it takes 0.0156 seconds between when the valve closes and when it opens again. At 1,300 fps multiplied by 0.0156 seconds, the pressure wave would travel about 20 feet. But, since must go up the intake runner and then come back, the intake runner would only have to be half this length or about 10 feet.
Two things become apparent after doing this calculation:
1. The tuning of the intake runner will only have an effect in a fairly narrow RPM range. If we redo the calculation at 3,000 rpm, the length calculated would be completely different.
2. Ten feet is too long. You can't fit pipes that long under the hood of a car very easily.
There is not too much that can be done about the first problem. A tuned intake has its main benefit in a very narrow speed range. But there is a way to shorten the intake runners and still get some benefit from the pressure wave. If we shorten the intake runner length by a factor of four, making it 2.5 feet, the pressure wave will travel up and down the pipe four times before the intake valve opens again. But it still arrives at the valve at the right time.
There are a lot of intricacies and tricks to intake systems. For instance, it is beneficial to have the intake air moving as fast as possible into the cylinders. This increases the turbulence and mixes the fuel with the air better. One way to increase the air velocity is to use a smaller diameter intake runner. Since roughly the same volume of air enters the cylinder each cycle, if you pump that air through a smaller diameter pipe it will have to go faster.
The downside to using smaller diameter intake runners is that at high engine speeds when lots of air is going through the pipes, the restriction from the smaller diameter may inhibit airflow. So for the large airflows at higher speeds it is better to have large diameter pipes. Some carmakers attempt to get the best of both worlds by using dual intake runners for each cylinder -- one with a small diameter and one with a large diameter. They use a butterfly valve to close off the large diameter runner at lower engine speeds where the narrow runner can help performance. Then the valve opens up at higher engine speeds to reduce the intake restriction, increasing the top end power output.
Thier butterfly valve, is our VDI. Keep it working guys!
Old May 24, 2002 | 03:25 PM
dre_2ooo's Avatar
No offense, but DUH!
Old May 24, 2002 | 03:37 PM
blu_gxl's Avatar
well i don't have vdi but that was atleast informative in a mathmatical sence
Old May 24, 2002 | 05:46 PM
MtnRacer's Avatar
infini guru
Thanks! I have a clearer understanding of intake runners now.
Steve
Old May 24, 2002 | 09:40 PM
pp13bnos's Avatar
Pineapple Racer
Great info. Now we need like a 3 step vdi...or a 4 step. That would be cool. CJ
Old May 24, 2002 | 09:50 PM
NZConvertible's Avatar
I'm a boost creep...
...or even better, infinitely variable length intake runners like the R26B! Might not fit under the bonnet of an FC though...
Old May 24, 2002 | 10:00 PM
von's Avatar
von
Well bottom line is if u open the VDI u lose mid range and if its close u lose top end but if its automatic then u get both but no actual gainz as far as added hp.
Old May 24, 2002 | 11:08 PM
hm...at least i kno what a VDI is right now...=P
Old May 24, 2002 | 11:18 PM
QC Motorsports
Well crap. IO hate sounding stupid but I just looked through my Haynes book and I couldn't find a VDI. Could you tell me where its located so I can understand what it does?
Charles
Old May 25, 2002 | 12:08 AM
rx-7fc's Avatar
here is a pic for people that don't know what it looks like
Old May 25, 2002 | 12:47 PM
QC Motorsports
O.K. I see. Why the heck would you want to disable that? The engine shouldn't work right. Wrong air flow and everything. If you disable it you would have a wrong air flow messing with your engine, right?
Charles
Old May 25, 2002 | 03:46 PM
pp13bnos's Avatar
Pineapple Racer
Most people get rid of it because they get rid of all the emmisions stuff. It makes the car look better, but does'nt add any hp. Like the above post says, if its not working, you'll be loosing hp somewhere, and if it is working....then...well....its working. CJ
zyph3r
Canadian Forum
Sep 16, 2018 07:14 PM
He's On Toroids
NE RX-7 Forum
48
Oct 19, 2015 08:58 PM
antman0408
Oct 5, 2015 04:33 PM
