Speedometer
Old Mar 9, 2009 | 07:29 PM
pure imagination's Avatar
FL Speedometer
i have an 88 rx-7 convertible and the rpm gauge is working fine but the speedometer and odometer are not working i'm wondering if anyone would know what may be causing it
keep in mind i have already taken the gauge cluster out and checked the cable behind it it was firmly placed in so i unplugged it and cleaned it but, still no results
Old Mar 10, 2009 | 09:01 AM
Icemark's Avatar
probably disconnected at the transmission or the cable is broken internally
Old Mar 10, 2009 | 09:47 AM
FL
how would i go about fixing the cable internally?
Old Mar 10, 2009 | 03:59 PM
RotaryRocket88's Avatar
Top Down, Boost Up
You don't. You would just buy a new one to replace it.
Old Mar 10, 2009 | 05:20 PM
FL
thanks both of you guys and i also was wondering how long it would take to replace?
Old Mar 10, 2009 | 05:26 PM
Icemark's Avatar
It will take more time to remove the gauge cluster to get to the back of the gauges than it will to do any other part of the swap.
Maybe an hour total time.
Old Mar 10, 2009 | 09:17 PM
Top Down, Boost Up
Removing the gauge cluster is a pain in the ***. The electrical plugs are very difficult to pull out, and the speedometer cable limits how much room you have to move around. It's just enough to jam your left arm in there.
Like Icemark said, everything else will be easy. Just watch out when you unscrew the cable from the transmission, or you'll get oil all over yourself.
