What do wheel adapters do to offset?
Old Mar 8, 2009 | 02:23 PM
7-sins's Avatar
thats not paint....
I came across some nice wheels, but they are going to need adapters to fit the FD bolt pattern. The rears are 18x10.5 with a 38 offset. From what I have read on here thats tight if not possible already. I think the adapters are like 20mm? so does that add or subtract from the offset?
Be easy on me, I am just starting to look into aftermarket wheels, been running the stockers for too long
Old Mar 8, 2009 | 02:33 PM
KaiFD3S's Avatar
SINFUL7
you may be able to make them work with some rolled fenders and slightly streched tires
No need for spacers
Old Mar 8, 2009 | 02:54 PM
Mahjik's Avatar
Mr. Links
That would subtract from the offset (so 38 - 20 = +18mm). It would probably be better to see if the wheels could be modified for the bolt pattern rather than using an adapter.
Old Mar 18, 2009 | 05:11 PM
ARD T2's Avatar
I concur.
Spacers will lower offset, in turn putting more load on your wheel bearings.
What's the boltpattern for the wheels? What are the wheels?
Rishie
pjr
13
Sep 3, 2015 11:44 AM
