do you know what this is ?????
Old Mar 5, 2009 | 08:58 PM
bprotary's Avatar
in my car this is just pluged up with a skrew, is it part of the omp? what do i do to it?
Old Mar 6, 2009 | 07:58 AM
Go48's Avatar
Originally Posted by bprotary
in my car this is just pluged up with a skrew, is it part of the omp? what do i do to it?[/IMG]
Yeah, that's the manifold for the air lines to the oil injectors. See the attached image.
"What do I do with it?" Depends on whether or not you have disabled the MOP. If so, you don't need it. If you still want the MOP system to be operative, you gotta connect the "skrew"ed thing to a source of air with a hose. Off hand I don't recall just where it is connected.
Old Mar 6, 2009 | 03:55 PM
White_Shadows's Avatar
MOP or OMP? Damn acroynms
Old Mar 7, 2009 | 06:02 AM
Go48's Avatar
Mazda calls it the Metering Oil Pump (MOP) in the factory service manual. Apparently some owners/members on the forum prefer the term, Oil Metering Pump (OMP). So take your pick.
Old Mar 7, 2009 | 09:38 AM
hanman's Avatar
I would highly suggest that you stuff rags or something in all of those openings on your engine. Especially, if it is outside like in the picture.
Old Mar 7, 2009 | 07:21 PM
RotaryRocket88's Avatar
Top Down, Boost Up
When you put the engine back together, that line will be connected to the larger port on the front of the throttle body. It requires a metered air source rather than vacuum.
Old Mar 8, 2009 | 01:25 AM
trochoid's Avatar
Old Fart Young at Heart
It' no so much of a metered air source as it's a filtered fresh air source. If connected to a vacuum source it would suck the oil backwards.
