what can I block off on the LIM/UIM
Old Mar 2, 2009 | 07:52 PM
BC-FD3S's Avatar
My engine is currently stripped to the shortblock, and I'm starting to put it back togehter. I'm going single... FYI.
On the LIM near the middle there is a larger sized "nipple" sticking out of the LIM. Can I block this off?
It looks like it runs into the engine kind of...
Old Mar 2, 2009 | 11:35 PM
BC-FD3S's Avatar
helloooo... someone.
Old Mar 3, 2009 | 07:58 AM
NewbernD's Avatar
Tequila? ..it's like beer
Assuming you're talking about an FD LIM since you did not specify..
The nipple just to the rear (right in this pic) of center and points to the rear.. you can block this off and eliminate the solenoid. This was the OEM FPR solenoid line (not the reference line).
The larger line to the front (left) that points up.. This line helps to atomize the primary injectors. If you use side feed injectors then you should still us this. If you use top-feed primaries then you can block this off.
Pic for reference
Old Mar 3, 2009 | 08:15 AM
Smitter's Avatar
94 Single Turbo FD
look into the "banzai block off plate kit". it will let u know what is commonly eliminated.
Old Mar 3, 2009 | 03:44 PM
BC-FD3S's Avatar
I already have the BOP kit installed. I was just curious about the nipples. The one I was talking about was the one on the left of that picutre. Where does it attach to when stock?
I will be running 1300cc and 850cc side feeds.
Logan Reinisch
44
Sep 17, 2018 12:20 PM
cook11
V-8 Powered RX-7's
Oct 2, 2015 11:52 AM
jarjarbinks
Sep 25, 2015 11:03 PM
MidnightOwl
Sep 25, 2015 10:24 PM
