No Start :(
Old Mar 2, 2009 | 10:37 AM
Cubanskater45's Avatar
Learning
CA No Start :(
So lately after sitting for a while (1-2days) my car had a hard time starting. At first it would happen where it would start and sputter a bit then clean up, and some white smoke that smelled like fuel would puff out. Then i would turn it off and start it up again and it would run fine.
This morning it started right up and did the whole sputtering thing but it would not start up again after like it was been. I tried doin the easy flood fix but nothing so far. Then when i crank it i get some nice white smoke (gas) comin out again. Im pretty sure i have some leaky injectors. i just wanted some confirmation befor i spend money . And i think ima head over and get some spark plugs and some 2stroke oil and try the more complex method soon. Why does this happen when i need to get to work?
Old Mar 2, 2009 | 11:28 AM
cmanns's Avatar
Smoke moar
bad luck?
If S5 push pedal before starting and wait for it to catch (Will disable fuel) if S4 make a fuel cut switch so you don't need to pull ta plugs
best luck
ZacMan
Sep 19, 2015 09:20 PM
sherff
Sep 12, 2015 12:22 PM
whinin
Sep 5, 2015 11:52 PM
