Have any wheel or tire ?
Old Mar 1, 2009 | 11:12 PM
Halfbridge's Avatar
Brap Brap Brap
Hey guys I have noticed a lot of questions about wheels and tires. If you have any questions I should be able to help. I work for Discount Tire Co. and have direct conections to just about all the manufactures. Info is very easy to get and I could probable answer alot without calling. So feel free to ask
Old Mar 2, 2009 | 05:06 PM
1991rx7vert's Avatar
these are the rims I want to get I have a 91 vert black... http://cgi.ebay.com/ebaymotors/18-Sp...ht_4045wt_1217 ... or these... http://cgi.ebay.com/ebaymotors/17-XX...ht_3927wt_1197
what benefits come from staggered wheels???
Old Mar 2, 2009 | 09:10 PM
Halfbridge's Avatar
Brap Brap Brap
mostly allows to run the widest tire on all 4 corners without having stearing problems. Other than that just for the looks. The more the rubber in the back the better it looks and performes. I think. I run a staggered set so i can get a wider tire in the back for traction.
Old Mar 3, 2009 | 12:46 AM
HotRodMex's Avatar
I want to buy the new NT-05 in 255/40-17, and Nitto recommends mounting on no lower than an 8.5 wide rim. I have an 8. Will this really be a problem, or did they just have to draw the line somewhere?
I currently have 245/40-17s on there right now and I don't see how another few MM would push things over the brink.
Old Mar 3, 2009 | 01:54 AM
BC-FD3S's Avatar
a 255 on an 8'' wheel is kind of on the small side (for the wheel). I would recommend a 235/40 if Nitto makes that.
with a 255, your tire will be... like a "muffintop"
