cluth shot
Old Mar 1, 2009 | 04:31 PM
jla_gtu's Avatar
johnny
cluth shot
hey guys i was on way home from lawerence kansas to pittsburg kansas today and i couldnt get into gear without forcing it. my cluch pedal then lost all pressure and i had to drive 2 hrs with no clutch...not sure if its clutch cable or master cylinder help me out if you know please so i can fix
Old Mar 1, 2009 | 04:34 PM
RotaryRocket88's Avatar
Top Down, Boost Up
Check for leaks in the system. Fluid level should give you a quick idea whether you've got a leak. The master cylinder, clutch line and slave cylinder all need to be inspected.
Old Mar 1, 2009 | 04:42 PM
jla_gtu's Avatar
johnny
ok i have to pressure what so ever in pedal im wonderin if cable just snapped...anyone have these symptoms before?
and thanks man im about to go check everything...a lil stressed right now from a scary drive home haha
Old Mar 1, 2009 | 09:13 PM
misterstyx69's Avatar
Retired Moderator, RIP
the clutch has NO cable.it is Hydraulic.
Like "the Rocket Man" Said.Check your clutch fluid level.If it is down Put some in so you can Check to see where it Went to.It sounds like either your slave or line went.Your master would show signs of starting to go,Not Go just like what you described.
remember,even If the Fluid Stays up,YOu are going to have to Replace something.It is not just an Add fluid and everything is alright deal.If the Clutch let go,there is a reason for it,and it wouldn't magically fix itself after just adding fluid.So,look into clutch Hydraulic replacement On the Forum.Look into bleeding the System to get air out also.
Old Mar 1, 2009 | 10:00 PM
lonetlan's Avatar
Too Many Questions
If you still have the rubber hose, there could be cracks in it. Thats what I had. I drove around with brake fluid with me. The symptoms I would have before the clutch went to the floor were: a weak peddle, harder to shift into gear, being stuck in nuetral, and pedal stuck to the floor. Order a Stainless Steel clutchline, its $20 and works wonders. Also, bleed your system, air in the line makes it worse. Another thing to do if it isn't the line, park over paper, or dry concrete, let your car sit for a minute, and then back up a little bit, look for fresh wet spots in the area you were just at. If the middle of the spot is wet, it could be the slave cylinder, if it is wet towards the left side, its the master cylinder. Rebuild kits are give or take $25. Also, see if wrapping the threads with Teflon tape, (plumbing tape thats white and frays easilly) it plugs leaks. I hope this helped, because this is what I did. Also search, I made a thread were I needed help with some of this stuff, I got too many questions.(Really sorry for the wall of words)
Zinraf
Oct 1, 2015 01:09 PM
