Porting Question
Old Mar 1, 2009 | 09:50 AM
NoPis10's Avatar
Committee Member #2
FL Porting Question
When porting the exhaust ports on the housing, do the sleeves get removed or should they be left in???
Thanks in advance...
Joe
Old Mar 1, 2009 | 10:16 AM
IRPerformance's Avatar
Sponsor
There is no reason to remove them. Don't go larger that the sleeve as it acts as a heat shield.
Old Mar 1, 2009 | 10:18 AM
NoPis10's Avatar
Committee Member #2
Thanks....
Old Mar 3, 2009 | 08:23 PM
diabolical1's Avatar
on sleeve removal ... generally speaking, no. however, some people do.
Old Mar 3, 2009 | 10:26 PM
mono4lamar's Avatar
In the burnout box...
Depending how big your port is you will need to taper down the sleeve... I've done it more than once!
Old Mar 5, 2009 | 05:28 PM
NoPis10's Avatar
Committee Member #2
I have come to realise it's personal preference...
Some say NO while others say it doesn't matter you can remove them...
L8R
hotshot2014
Jul 18, 2017 02:30 PM
