Power FC What is the PIM Volt for?
Old May 23, 2002 | 06:56 PM
JAMMNN's Avatar
I see
NORMAL
OPTION 1
OPTION 2
Ans so on what does this mean? and what do the options change?
Old May 23, 2002 | 09:10 PM
cewrx7r1's Avatar
Eye In The Sky
Only NORMAL works for our cars. The manual explains what inside the NORMAL door and what it is used for.
Old May 26, 2002 | 06:12 AM
jspecracer7's Avatar
1JZ powered
Re: What is the PIM Volt for?
Originally posted by JAMMNN
I see
NORMAL
OPTION 1
OPTION 2
You change that when you change your MAP sensor to a 2BAR/3BAR Map sensor. Keep normal if your map sensor is normal.
Old May 28, 2002 | 02:08 PM
2FAST7S's Avatar
change it to option 1 and watch your car struggle to idle. Other than that, it will not boost right but will be "driveable".
Old May 28, 2002 | 10:40 PM
7-sins's Avatar
thats not paint....
Keep it on normal.. anything else is BAD.. I tried driving on option 4 cuz I didn't know that it was switched. I thought I had a bad problem with my car, anything above 6k the engine was missing bad. Makes sense because the car thought it was getting 3 more pounds of boost.
Old Jun 5, 2002 | 01:15 PM
nocab72's Avatar
03 Cobra Killer
7-sins - actually it probably thought it was getting 3 TIMES the pounds of boost, not 3 pounds more (unless of course you were running 1 psi).
k
Old Jun 6, 2002 | 11:37 PM
yy4u's Avatar
what does PIM stand for? or is it even an acronym? I guess its probably in the manual, but i'm lazy
imitek
Oct 18, 2015 03:35 PM
FC3S Timmy
16
Oct 3, 2015 01:08 AM
astrum
Sep 7, 2015 11:41 PM
The1Sun
Sep 7, 2015 10:21 PM
